Legend009 Posted January 26, 2017 Posted January 26, 2017 Hy guys, i have the rear ep82 discs and its quite a challenge to come buy calipers and the mounts for the ep82. Can a vitz rs rear caliper fit to a rear ep82 disc and if possible wat mods should be done? Quote
akyakapotter Posted January 26, 2017 Posted January 26, 2017 There isn't any that I no of that fit due to our hand brake set up.Cheers nick Quote
Legend009 Posted January 27, 2017 Author Posted January 27, 2017 🤒🤒🤒 gues i just have to go on hunting for the calipers. But why do guys prefer leaving the drums behind wldnt it help with the brake power to stop the vehicle? Quote
JamesD89 Posted January 27, 2017 Posted January 27, 2017 Probably better off with drums on the back as stock rear brakes are not great, I would imagine people with n/a starlets swap to discs purely for looks. I have a pair ep82 rear calipers here if you can't find any in your country.James Quote
Legend009 Posted January 28, 2017 Author Posted January 28, 2017 Im all the way in kenya. Am converting from a 4efe to an fte thats why i wanted to convert the rear drums to discs. Getting parts for our starlets here is tricky Quote
daniel_g Posted January 28, 2017 Posted January 28, 2017 Im all the way in kenya. Am converting from a 4efe to an fte thats why i wanted to convert the rear drums to discs. Getting parts for our starlets here is trickyThere is literally no point whatsoever the drums will be fine. Quote
Legend009 Posted January 29, 2017 Author Posted January 29, 2017 So if i am to upgrade the brakes i just change to the GT braking system For the front that is Quote
JamesD89 Posted January 29, 2017 Posted January 29, 2017 So if i am to upgrade the brakes i just change to the GT braking systemFor the front that is Quote
Legend009 Posted January 29, 2017 Author Posted January 29, 2017 Thanks guys. Il start hunting. So discs stay behind. Bro by carriers u meant the lines or ?? A lil lost Quote
JamesD89 Posted January 29, 2017 Posted January 29, 2017 Thanks guys. Il start hunting. So discs stay behind. Bro by carriers u meant the lines or ?? A lil lost The mounts buddy. Quote
Legend009 Posted January 29, 2017 Author Posted January 29, 2017 Oh okay. Il go check them out and will update. Thanks buddy Quote
