avster Posted February 28, 2017 Posted February 28, 2017 Hi guys just a quick one was wondering why since i installed my TD04 setup my dump valve does not dump i am using a front mount intercooler and installed the dump valve on the cold side of the intake closer to the intake manifold just want to know if this is normal as im not to keen on the turbo chatter as its not dumping. Quote
turbominicooper Posted February 28, 2017 Posted February 28, 2017 If its not dumping it's either:- no boost generated- Dv not plumed in correctly- Dv faulty Quote
adzy Posted February 28, 2017 Posted February 28, 2017 Are you running different boost pressure than old set up? Quote
avster Posted March 1, 2017 Author Posted March 1, 2017 (edited) I am running more boost than the old setup is there any link as to how the plumbing should be as i have mine +- 250mm from the intake manifold. i am running .9 bar boost at highest. I also have an external wastegate fitted to my screamer pipe. Edited March 1, 2017 by avster Quote
alexoc01 Posted August 12, 2017 Posted August 12, 2017 Hi mate did you ever fix the issue as I'm having the same problem and I have the exactly the same set up lol? Thanks Quote
