Hi guys just a quick one was wondering why since i installed my TD04 setup my dump valve does not dump i am using a front mount intercooler and installed the dump valve on the cold side of the intake closer to the intake manifold just want to know if this is normal as im not to keen on the turbo chatter as its not dumping.
I am running more boost than the old setup is there any link as to how the plumbing should be as i have mine +- 250mm from the intake manifold. i am running .9 bar boost at highest. I also have an external wastegate fitted to my screamer pipe.
Edited by avster
  • 5 months later...
