paddy Posted March 10, 2017 Posted March 10, 2017 Need to fit a blitz boost controller, it has a wire for speed and a wire for rpm, can anyone tell me which wire on the ecu is for rpm? Looked at a ecu pin out but it wasn't quite clear which one was correct Quote
gorganl2000 Posted March 10, 2017 Posted March 10, 2017 http://www.toyotagtturbo.com/forums/showthread.php?51852-turbosmart-Eboost-2-rpm-issue i hope you have better luck than me with my eboost2 but then again blitz is japanese like the car,,,so you should find a good reading Quote
RobSR Posted March 10, 2017 Posted March 10, 2017 Pin 4 on the 26 Pin plug if you have a glanza. Marked NE on pinouts. Quote
Stu Posted March 11, 2017 Posted March 11, 2017 Your better off using an output not a trigger input. Any back feed or electrical interference on the NE 24tooth trigger with cause the ecu to no have a clean triggering signal. I'd be using IGT instead where possible. Quote
RobSR Posted March 11, 2017 Posted March 11, 2017 Your better off using an output not a trigger input. Any back feed or electrical interference on the NE 24tooth trigger with cause the ecu to no have a clean triggering signal. I'd be using IGT instead where possible. Quote
paddy Posted March 18, 2017 Author Posted March 18, 2017 Thanks for the advice very helpful. Can anyone tell me where the best place to tap in the 12v power feed for the boost controller? Apart from in the back of the head unit, bought a project car and doesn't look like there's and wires or plugs for a head unit Quote
paddy Posted March 18, 2017 Author Posted March 18, 2017 Would the back of the cigarette lighter socket be ok? Quote
5e colin Posted March 19, 2017 Posted March 19, 2017 Would the back of the cigarette lighter socket be ok? no to much current gose tru it tap of a smal gauge wire in cockpit fusebox is yours gtt or micra ?? Quote
Stu Posted March 22, 2017 Posted March 22, 2017 Cigarette lighter circuit is fine for what you need. Quote
5e colin Posted March 22, 2017 Posted March 22, 2017 Cigarette lighter circuit is fine for what you need. dont that draw out to much amps ??? was always advised not to tap into any thick gauge wire Quote
Stu Posted March 22, 2017 Posted March 22, 2017 Boost controllers draw very little current so won't be an issue. Thick wire is usually best as it's got more current carrying capacity and they are usually miles away from reaching the max Quote
