richglanzav Posted March 12, 2017 Share Posted March 12, 2017 Right guys i need a lead for a computer at work. The setup is 2 PC's that work off one mouse keyboard and monitor via a KVM switch. I need to print stuff off both of them and it works providing i keep swapping the usb into each tower that i need to print off. But i want a splitter lead that will allow me to print off both as and when i want. Is this lead ok?http://www.maplin.co.uk/p/maplin-usb-20-a-to-b-dual-power-cable-3m-a62qc Quote Link to post Share on other sites
Calum122 Posted March 12, 2017 Share Posted March 12, 2017 We used something like this at our house: https://www.amazon.co.uk/MT-VIKI-Ports-Printer-Switch-MT-1A4B-CF/dp/B00DRG1QHA But nowadays it's all Wifi. Quote Link to post Share on other sites
richglanzav Posted March 12, 2017 Author Share Posted March 12, 2017 Need it as cheap as pos. I didnt think i needed networking as due to the kvm switch only one pc is live at a time. And they both work if plugged in to one pc or the other Quote Link to post Share on other sites
karl. Posted March 12, 2017 Share Posted March 12, 2017 Keep the printer plugged into one computer and share the printer on the network and print that way? Quote Link to post Share on other sites
richglanzav Posted March 12, 2017 Author Share Posted March 12, 2017 Hard to explain but the one comp is like a system computer on linux and the other is just a windows admin comp. So not sure thats possible Quote Link to post Share on other sites
TimD Posted March 13, 2017 Share Posted March 13, 2017 The cable you've posted is for powering a device using two USB ports, rather than sending data to a device from two USB ports, if that makes sense? Looks like you'll need something like this: http://www.ebay.co.uk/itm/Belkin-2X1-USB-Peripheral-Switch-for-printer-scanner-and-USB-device-F1U201-/251394289494?hash=item3a88446f56:g:2gUAAOxy9X5TaQK4 I have no experience with the above, but understand what you're trying to do, and that should work. Quote Link to post Share on other sites
nikhilkamdar12 Posted March 13, 2017 Share Posted March 13, 2017 I presume from what you have said above the printer is not a LAN printer and just connects via a lead to the PC. It does not matter if the 2 PC you are using is a Linux box or Windows box providing the correct drivers are installed. You can achieve what you want with some like this... https://www.amazon.co.uk/USB-2-0-Manual-Switch-Peripherals/dp/B005LMX0IG/ref=pd_cp_computers_0 But if a LAN printer you can just share across network and job done Nikhil Quote Link to post Share on other sites
Calum122 Posted March 13, 2017 Share Posted March 13, 2017 Pretty sure I mention this initially?? Quote Link to post Share on other sites
nikhilkamdar12 Posted March 13, 2017 Share Posted March 13, 2017 Pretty sure I mention this initially?? My bad mate, didn't see your post! Both will work Quote Link to post Share on other sites
TimD Posted March 13, 2017 Share Posted March 13, 2017 You did,Pretty sure I mention this initially?? Yup, linked to a product that is no longer available. Quote Link to post Share on other sites
