GT Phayer Posted April 8, 2017 Posted April 8, 2017 Hi guys i know when you remove ac and fit a alloy rad, when wired up the fan runs constant until you bridge the ac wire. However i am getting rid of all the ac loom and fuse box so how can i get round the problem of the fan running all the time ? Quote
GT Phayer Posted April 8, 2017 Author Posted April 8, 2017 There must be a way without having a manual switch for the fan in the car Quote
Calum122 Posted April 8, 2017 Posted April 8, 2017 I'm sure there is if you trace the wiring diagram Quote
maddox710 Posted July 23, 2017 Posted July 23, 2017 Sure it needs something like a 3ohm resistor Quote
GT Phayer Posted July 23, 2017 Author Posted July 23, 2017 Ok but if all the wires are being cut out how can i get round it ? Quote
TrisK Posted July 24, 2017 Posted July 24, 2017 Ok but if all the wires are being cut out how can i get round it ? follow the wires you would bridge back to the furthest back point where you going to cut them, be that at the fusebox or at a control box of some description and bridge them there Quote
GT Phayer Posted July 28, 2017 Author Posted July 28, 2017 Is it the top and bottom wires you bridge or left and right on the plug ? Quote
GT Phayer Posted August 2, 2017 Author Posted August 2, 2017 Does any one know if its left to right or top to bottom on the plug ? Quote
