chriswep91 Posted June 26, 2017 Share Posted June 26, 2017 Des the catch tank have to have a filter on it? only the one i have doesn't it just has the two hose inlets? Thanks Quote Link to post Share on other sites
patman Posted June 27, 2017 Share Posted June 27, 2017 Will you be running it pcv valve to catch can and catch can to inlet manifold? Quote Link to post Share on other sites
5e colin Posted June 27, 2017 Share Posted June 27, 2017 (edited) Don't need breather filter there's many ways to set up a kit rule is 2 pipes in 2 out for breathing or it is a 2 pipes in 1 useless serup Edited June 27, 2017 by 5e colin Quote Link to post Share on other sites
chriswep91 Posted June 28, 2017 Author Share Posted June 28, 2017 Ill be running two pipes off the rocker to a catch tank? Quote Link to post Share on other sites
starletezy Posted June 29, 2017 Share Posted June 29, 2017 This is my setup if it helps Quote Link to post Share on other sites
morgey Posted June 29, 2017 Share Posted June 29, 2017 If its only got 2 pipes its designed to go inbetween rocker cover and an original fitting, ie pcv-catchcan-inlet manifold Rocker breather-catchcan-intake piping (recirc dumpvalve on 4eftes) Most people do what ezy has and get 2 ins with a breather filter on the catch can. Quote Link to post Share on other sites
chriswep91 Posted June 29, 2017 Author Share Posted June 29, 2017 Yeah i now but my catch tank doesn't have a breather so was wondering if i actually need one?? Quote Link to post Share on other sites
starletezy Posted June 29, 2017 Share Posted June 29, 2017 Yes Quote Link to post Share on other sites
akyakapotter Posted June 29, 2017 Share Posted June 29, 2017 Just drill a hole in the side at the top so it can breeth imo.Cheers nick Quote Link to post Share on other sites
