glanzadude Posted June 29, 2017 Share Posted June 29, 2017 Lads my engine & bay could do with a good clean is it safe to power wash it are just leave it be till sometime i have to remove the engine? Quote Link to post Share on other sites
SpikeyJp_68 Posted June 29, 2017 Share Posted June 29, 2017 Lads my engine & bay could do with a good clean is it safe to power wash it are just leave it be till sometime i have to remove the engine?Cover up the distributor,coilpack and igniter,fusebox and wash to your hearts content. Just use low pressure and always keep moving as not to drive water into places. Make sure no water gets past your spark plug seals aswell Quote Link to post Share on other sites
Gainzy Posted June 29, 2017 Share Posted June 29, 2017 Remove engine..do a proper job imo Quote Link to post Share on other sites
Si@Fiske Posted August 6, 2017 Share Posted August 6, 2017 Cover up the distributor,coilpack and igniter,fusebox and wash to your hearts content. Just use low pressure and always keep moving as not to drive water into places. Make sure no water gets past your spark plug seals aswell Quote Link to post Share on other sites
Ollieh17 Posted August 6, 2017 Share Posted August 6, 2017 Just use a good degreaser, brush it and wash off with lower power hose Quote Link to post Share on other sites
tahiRR Posted August 20, 2017 Share Posted August 20, 2017 Use apc in spray bottle spray engine bay and steam clean everything at same time wipe the things steam cleaned with microfibercloth Quote Link to post Share on other sites
The Trooper 1815 Posted September 18, 2017 Share Posted September 18, 2017 Buy cheap multi-surface cleaner from your local discount shop for 99p a litre. Spray on and scrub off with some water. If it is good enough for your kitchen then your engine will be fine. Also works on wheels too. Unless you want to spend a fortune and brag to your mates about how much you spent on cleaning your engine Quote Link to post Share on other sites
glanzadude Posted September 18, 2017 Author Share Posted September 18, 2017 Buy cheap multi-surface cleaner from your local discount shop for 99p a litre. Spray on and scrub off with some water. If it is good enough for your kitchen then your engine will be fine. Also works on wheels too. Unless you want to spend a fortune and brag to your mates about how much you spent on cleaning your engine I did that worked great Quote Link to post Share on other sites
George2k8 Posted September 16, 2018 Share Posted September 16, 2018 Use a steamer mate then wipe it off with microfiber cloth..... use it on all engines when detailing the engine bay and its great Quote Link to post Share on other sites
