Zak.p Posted July 20, 2017 Posted July 20, 2017 Anyone have any ideas what this might be and how I can check? Seems to be leaking only out of the breather filter, cheers Quote
Ollieh17 Posted July 20, 2017 Posted July 20, 2017 Could be a bad sign, piston rings on way out etc. I'd compression test it, if healthy consider getting rid of the filter and get a catch can or reinstate standard breather Quote
Zak.p Posted July 20, 2017 Author Posted July 20, 2017 Sweet thanks for the help I'll get it compression tested asap got a lot of work ready to be done to it so hoping it's all good! Got another breather on the way will look into catch can cheers Quote
starletezy Posted July 20, 2017 Posted July 20, 2017 That would be piston rings for sure mate nothing should be coming out of there on a healthy engine. Quote
Zak.p Posted July 20, 2017 Author Posted July 20, 2017 That would be piston rings for sure mate nothing should be coming out of there on a healthy engine.Cheers will have a look properly tonight not ideal a day or 2 away from getting it converted to td04 lol may have to think about forged engine if it is the rings seeing as I'm going for 240bhp+ Quote
Zak.p Posted July 20, 2017 Author Posted July 20, 2017 If it is the piston rings and I'm planning on 240bhp+ should I get forged pistons and rods? Was looking at TD forged internals package would i need anything else other than what's listed here for a basic forge (really not clued up on forging engines)Wossner Forged Piston Set (74mm, 74.5mm or 75mm)Scat Forged Conrod KitACL Full Engine Bearing Set (STD or 0.25)Athena MLS Headgasket (1.2mm or 1.4mm)ARP Headbolt SetThanks for the help Quote
T-dog Posted July 20, 2017 Posted July 20, 2017 (edited) It's the ringlands on the pistons for sure , had a similar problem myself Edited July 20, 2017 by T-dog Quote
Zak.p Posted July 20, 2017 Author Posted July 20, 2017 It's the ringlands on the pistons for sure , had a similar problem myselfYeah looking like it's gonna be to do with that unfortunately! What did you have to replace and did you do it yourself? Quote
T-dog Posted July 20, 2017 Posted July 20, 2017 I bought a forge engine in the end and just left the old engine in the shed lol , I'm to lazy lol 😂 Quote
Zak.p Posted July 20, 2017 Author Posted July 20, 2017 Sounds like something I'd do to be fair haha! Gonna compression test asap if piston rings will just replace with forged pistons, rods etc would the TD kit I posted be all I need do u know? Quote
T-dog Posted July 20, 2017 Posted July 20, 2017 Got to be done lol , yeah td kits are good , you will probably still need to have the crank notched and some other bits done , not 100% sure on a full build , give them a call dude Quote
Zak.p Posted July 20, 2017 Author Posted July 20, 2017 Yeah heard I would need it notched not sure on what else would need to get but yeah nice one mate will ring them once compression tested Quote
Zak.p Posted July 23, 2017 Author Posted July 23, 2017 It's all good lol compression test was all 180psi apart from 2nd cylinder 178psi think the breather was fucked, all good with new breather on now! Quote
patman Posted July 23, 2017 Posted July 23, 2017 Yeah these aftermarket breathers you stick on top of the rocker cover seem to get blocked fairy quick, when I see mint engines with 2 lines going to the catch can with a little breather on top of the can surely that's a sign for trouble already? Quote
