Glanza AuA Posted September 4, 2017 Posted September 4, 2017 (edited) Hi guys i recently installed a new ss custom manifold notice more flow than stock, and now for some reason im unable to hold boost ? Does not stay at .7 bar and drops to .4 and stays, i already chk for hose leaks and mani leak can't find anything,also im still running stock actuator with blitz ebc,can anyone shed some light on this,thanks in advanced ð Edited September 4, 2017 by Glanza AuA Quote
Gainzy Posted September 4, 2017 Posted September 4, 2017 Check gasket leak did you use oem gaskets Quote
turbominicooper Posted September 4, 2017 Posted September 4, 2017 What boost controller u running? My e01 started doing this so I just ran hose from housing to actuator/wastegate and problem didn't happen agaib Quote
Glanza AuA Posted September 4, 2017 Author Posted September 4, 2017 (edited) Check gasket leak did you use oem gaskets yes mate fresh oem manifold gasket no leaks, i am noticing the increase turbo spool tough Edited September 4, 2017 by Glanza AuA Quote
Glanza AuA Posted September 4, 2017 Author Posted September 4, 2017 What boost controller u running? My e01 started doing this so I just ran hose from housing to actuator/wastegate and problem didn't happen agaib im using Blitz dual ebc in port to Turbo and out port to actuator Quote
Glanza AuA Posted September 4, 2017 Author Posted September 4, 2017 Can my stock actuator be causing this ? As the increase flow of mani is higher ? Unable to hold boost Sent from my iPhone using Tapatalk Quote
TD04GT Posted September 4, 2017 Posted September 4, 2017 I think your bang on there, the fact your blowing more air could cause a weak actuator to fail. Quote
Glanza AuA Posted September 5, 2017 Author Posted September 5, 2017 Modify it for EWG setup, job done. thats the plan mate,since its kind of my daily need to sort it for now Quote
Glanza AuA Posted September 5, 2017 Author Posted September 5, 2017 Just wanted to let know it was indeed the stock oem actuator,replaced it for a stiffer adjustable one,boost holds on the dot,thank you for all the response,appreciated Sent from my iPhone using Tapatalk Quote
