Andrew Miller Posted November 28, 2017 Posted November 28, 2017 Are they the same? I need a replacement for my Glanza. Cheers in advance Quote
akyakapotter Posted November 28, 2017 Posted November 28, 2017 Not sure on 4efe 4efte but i no gt and glanza arnt the same. cheers nick :) Quote
5e colin Posted November 28, 2017 Posted November 28, 2017 i know ( 4EFE.GI ) ( jap 100bhp 4efe ep82 ) and mk1 4efte ( 89 to 95.6 ) is the same sorry cant be any more helpfull then that Quote
maerijn Posted November 29, 2017 Posted November 29, 2017 Yes, they are the same, my 4EFTE engine is actually a 4EFE block with GT pistons Quote
Rob H@RCH Engineering Posted December 1, 2017 Posted December 1, 2017 They are completely different, the sump is a different shape on all 3 engines, the gt been the biggest sump of them all, the glanza is closer to the n/a but its not the same. Its better to fit the pick up to go with the sump you use Quote
Andrew Miller Posted December 1, 2017 Author Posted December 1, 2017 so if I change the sump as well that wont create any issue ? Quote
Rob H@RCH Engineering Posted December 1, 2017 Posted December 1, 2017 If you change both you will be fine mate, there all the same fitment just different shapes at the bottom. So the pick up needs to match the sump. Quote
Andrew Miller Posted December 1, 2017 Author Posted December 1, 2017 No worries cheers for that ! Quote
