Before it starts I know a turbo is faster. That is not an option for wat I'm doing. Also I know 5e is drop in but Very hard get here nd have a tsport yaris thats scrap
 Just wondering has anyone done it. Will two mounts nd shafts b right nd just fab d engine mount??
Rear mount and ns mount match up you just have to fabricate and OS mount, driveshafts should fit as the 5e/4e drops in the yaris bay and shafts fit so it's got to be the same the other way. If you do this I'll be keeping a keen eye. I've wanted to do this for ages but the cons outweigh the pros..... the yaris handles so much better than the starlet for a start. But you'll probably be the first to do it, have 105bhp out the bag and potenial for around 125bhp with a few mods. You can also turbo/supercharge the 1nzfe with off the shelf parts.
Edited by lukEp
No turbo has to b n/a so an exhaust nd intake nd ecu maybe throttle bodies see how d room is with intake on d front
Edited by iano21
2zz requires custom shafts nd chassis work nd front cross member work just think cud do this easier plus I already have a tsport there complete ha
The 1nzfe got weak rods so can' tmuch boost if you go down that route, having owned a yaris t sport I must say it's a great little fizzy engine, bomb proof like like the 4e
not sure how useful this info is, but the header/exhaust from the 4wd nze121 corolla is tucked closer to the engine and might fir the starlet firewall easier?
