chriswep91 Posted April 14, 2018 Posted April 14, 2018 Is there any visible differences so you Can tell the difference between the GT box and glanza box's? I'm changing mine and believe it may be a GT box, want to know how much fluid it needs and from reading they seem to hold different amounts? Cheers Quote
glanzagee Posted April 14, 2018 Posted April 14, 2018 The side casing on a ep91 is aluminum On the ep82 the endcasing is metal painted black Quote
00joeindastarb0 Posted April 14, 2018 Posted April 14, 2018 I thought the end casing on NA's was the pressed black steal, all turbo boxes seem to have the full aluminium casing. I have never been able to tell the difference although I have seen that some have a raised line going through the selector on the top of the box but I'm not sure this is specific to a particular model. Quote
glanzagee Posted April 14, 2018 Posted April 14, 2018 Your other option is to look though the driveshaft hole and see if it’s 8 bolt diff or 6 bolt Quote
daniel_g Posted April 14, 2018 Posted April 14, 2018 Its only MK1 GTs that have a 6 bolt diff. All turbo boxes i have seen have an alloy 5th gear casing. Wouldnt worry too much about how much oil it takes, fill it till its full. Quote
chriswep91 Posted April 15, 2018 Author Posted April 15, 2018 On 14/04/2018, 16:20:39, daniel_g said: Its only MK1 GTs that have a 6 bolt diff. All turbo boxes i have seen have an alloy 5th gear casing. Wouldnt worry too much about how much oil it takes, fill it till its full. Do you just fill them all till it leaks back out the filler hole? Quote
akyakapotter Posted April 15, 2018 Posted April 15, 2018 Just now, chriswep91 said: Do you just fill them all till it leaks back out the filler hole? no to the over flow on the front of the box. cheers nick its about 2.5L i believe Quote
chriswep91 Posted April 15, 2018 Author Posted April 15, 2018 1 minute ago, akyakapotter said: no to the over flow on the front of the box. cheers nick its about 2.5L i believe Yeah isn’t that the filler hole aswell? Quote
