chriswep91 Posted April 14, 2018 Share Posted April 14, 2018 Is there any visible differences so you Can tell the difference between the GT box and glanza box's? I'm changing mine and believe it may be a GT box, want to know how much fluid it needs and from reading they seem to hold different amounts? Cheers Quote Link to post Share on other sites
glanzagee Posted April 14, 2018 Share Posted April 14, 2018 The side casing on a ep91 is aluminum On the ep82 the endcasing is metal painted black Quote Link to post Share on other sites
00joeindastarb0 Posted April 14, 2018 Share Posted April 14, 2018 I thought the end casing on NA's was the pressed black steal, all turbo boxes seem to have the full aluminium casing. I have never been able to tell the difference although I have seen that some have a raised line going through the selector on the top of the box but I'm not sure this is specific to a particular model. Quote Link to post Share on other sites
glanzagee Posted April 14, 2018 Share Posted April 14, 2018 Your other option is to look though the driveshaft hole and see if it’s 8 bolt diff or 6 bolt Quote Link to post Share on other sites
daniel_g Posted April 14, 2018 Share Posted April 14, 2018 Its only MK1 GTs that have a 6 bolt diff. All turbo boxes i have seen have an alloy 5th gear casing. Wouldnt worry too much about how much oil it takes, fill it till its full. Quote Link to post Share on other sites
chriswep91 Posted April 15, 2018 Author Share Posted April 15, 2018 On 14/04/2018, 16:20:39, daniel_g said: Its only MK1 GTs that have a 6 bolt diff. All turbo boxes i have seen have an alloy 5th gear casing. Wouldnt worry too much about how much oil it takes, fill it till its full. Do you just fill them all till it leaks back out the filler hole? Quote Link to post Share on other sites
akyakapotter Posted April 15, 2018 Share Posted April 15, 2018 Just now, chriswep91 said: Do you just fill them all till it leaks back out the filler hole? no to the over flow on the front of the box. cheers nick its about 2.5L i believe Quote Link to post Share on other sites
chriswep91 Posted April 15, 2018 Author Share Posted April 15, 2018 1 minute ago, akyakapotter said: no to the over flow on the front of the box. cheers nick its about 2.5L i believe Yeah isn’t that the filler hole aswell? Quote Link to post Share on other sites
akyakapotter Posted April 15, 2018 Share Posted April 15, 2018 filler hole is ontop of the box Quote Link to post Share on other sites
