T-dog Posted July 17, 2018 Posted July 17, 2018 Hi , what pressure our people using for the radiator caps , 1.1 or 1.3 and why ? Thanks Toby Quote
Socks Posted July 18, 2018 Posted July 18, 2018 I use a 1.2Bar Cosworth item on my track GT. Found the stock cap and even the stock 1.2bar cap on the chinese civic rad just simply wont do the job on track. Quote
Calum122 Posted July 18, 2018 Posted July 18, 2018 1 hour ago, Socks said: I use a 1.2Bar Cosworth item on my track GT. Found the stock cap and even the stock 1.2bar cap on the chinese civic rad just simply wont do the job on track. I do wonder about these Starlets out on the track. You often see them pitting more often than the other Jap cars. Quote
T-dog Posted July 18, 2018 Author Posted July 18, 2018 3 hours ago, Socks said: I use a 1.2Bar Cosworth item on my track GT. Found the stock cap and even the stock 1.2bar cap on the chinese civic rad just simply wont do the job on track. Ok mate , that was my worrie with Chinese rad caps , will go for 1.3 bar cap then . Cheers socks Quote
Socks Posted July 18, 2018 Posted July 18, 2018 No worries man. I got mine from Demon Tweaks :) Quote
jayc-glanza17 Posted July 19, 2018 Posted July 19, 2018 On my rad made by pro alloy i use their 1.3 bar cap.. no issues in years of track abuse.. but pro alloy are btcc supplier so there testing is more thorough. Quote
adzy Posted July 21, 2018 Posted July 21, 2018 On 7/18/2018, 6:03:47, Socks said: I use a 1.2Bar Cosworth item on my track GT. Found the stock cap and even the stock 1.2bar cap on the chinese civic rad just simply wont do the job on track. What symptoms where you experiencing with civic rad cap? Been having some issues on track lately myself and hope the rad cap will sort it. Quote
Socks Posted July 21, 2018 Posted July 21, 2018 48 minutes ago, adzy said: What symptoms where you experiencing with civic rad cap? Been having some issues on track lately myself and hope the rad cap will sort it. Pushing Coolant to overflow and not drawing it back properly. Quote
adzy Posted July 21, 2018 Posted July 21, 2018 7 minutes ago, Socks said: Pushing Coolant to overflow and not drawing it back properly. Sounds similar, mine filling the expansion bottle then the low coolant would start to make it overheat Quote
Socks Posted July 23, 2018 Posted July 23, 2018 On 21/07/2018, 12:46:08, adzy said: Sounds similar, mine filling the expansion bottle then the low coolant would start to make it overheat Correct. Only did it on track though, I could never replicate the fault on the road... Could also be the H/G just bare in mind. Quote
adzy Posted July 23, 2018 Posted July 23, 2018 56 minutes ago, Socks said: Correct. Only did it on track though, I could never replicate the fault on the road... Could also be the H/G just bare in mind. Sounds exact same, no issues on road. Was worried it could be h/g at the time but not showing any symptoms it Quote
jayc-glanza17 Posted July 24, 2018 Posted July 24, 2018 Get it sniff tested if worried about headgasket matey. Quote
