glanzadude Posted August 11, 2018 Posted August 11, 2018 Hello all , My Starlet gt keeps failing the nct/mot on inbalance on the drivers rear. I have brand new full handbrake cables and new hall brake hoses. all brand new toyota seal kit for the calipers and new brake pads And still failed the test. what have i missed at thus stage every thing have been changed. I changed the proportioning valve too. Changed the rear caliper but the same thing, Any ideas lads? Quote
5e colin Posted August 12, 2018 Posted August 12, 2018 cut a groove in the calipe piston on our gt we only have 1 groove i made a 2nd 1 so there is a + on there so piston is closer to the pad by 1/4 turn did the job on my gt when i had inbalance isseus like that few years ago worth a try Quote
glanzadude Posted August 12, 2018 Author Posted August 12, 2018 UPDATE i bleed the rear brake with with a mate, the one that failed and there was a 3 are 4 BIG are bubbles. what you think???? Quote
lukEp Posted August 12, 2018 Posted August 12, 2018 Sounds like you fixed it. You can always go back to the garage and ask them to check it as you think you've fixed it. Quote
mccartney11 Posted August 13, 2018 Posted August 13, 2018 had same issue it was a bad proportion valve in the bay Quote
glanzadude Posted August 13, 2018 Author Posted August 13, 2018 what one you got to replace it? Quote
mccartney11 Posted August 13, 2018 Posted August 13, 2018 on the bulkhead you'll see a pipe from brake servo to a proportion valve going to each caliper Quote
glanzadude Posted August 14, 2018 Author Posted August 14, 2018 Did you buy a new one are 2nd hand one? i wonder would a glanza one do but my car has no abs Quote
mccartney11 Posted August 14, 2018 Posted August 14, 2018 I put in a used one as a new one wasn't available and I only had 3 days left for retest lol scraped through it ha Quote
glanzadude Posted August 14, 2018 Author Posted August 14, 2018 Did you get it from a disc are drum car? thanks Quote
