Bolts Posted March 5, 2019 Share Posted March 5, 2019 Hey I'm new here just wanting to know if any one has used a link monsoon ecu on 4efte in a standard ep91 was na now has a whistle in it's mouth Quote Link to post Share on other sites
RobSR Posted March 5, 2019 Share Posted March 5, 2019 Yes a few people are running them in Starlets. Capable ECU for the money with good features out the box. Quote Link to post Share on other sites
Bolts Posted March 5, 2019 Author Share Posted March 5, 2019 I have the 4efte out of a ep82 gt starlet and replaced the ep91 4efe what are some key things I should prior to the wiring up was going to standard distributor for now or should just fit cop now Quote Link to post Share on other sites
RobSR Posted March 5, 2019 Share Posted March 5, 2019 Well you will need all the key components for an EFI system to run, trigger inputs, map, tps, temps, injectors, coils etc etc, but they are easy to work out from the ECU pinouts online. You can use the dizzy if you like, however if going standalone its worth swapping to COP, namely for knock control id say, however there are plenty other benefits too. Quote Link to post Share on other sites
Ryan.Truesdale Posted March 6, 2019 Share Posted March 6, 2019 link atom is more than enough for a starlet if you are not wanting to spend a fortune Quote Link to post Share on other sites
Bolts Posted March 6, 2019 Author Share Posted March 6, 2019 Really dose it have enough inputs and outputs did you wire in the air solenoid on the intake Quote Link to post Share on other sites
Ryan.Truesdale Posted March 6, 2019 Share Posted March 6, 2019 have not got my car going yet but the plan is.... skyline spec 1 throttle position sensor, oil pressure sensor, wideband , intake air temp, wideband, coolant temp (I've probably missed one or two) Most of the old toyota sensors are gonna be on their way out and half \arent needed on standalone link atom can run coil packs too Quote Link to post Share on other sites
Bolts Posted March 6, 2019 Author Share Posted March 6, 2019 Really is the tps straight bolt up is it variable or open close was just going to use what is there get it up and running and replace as it fails I work for Toyota so can match with new stuff as for size and work out wiring later. What's with the wideband differences Quote Link to post Share on other sites
RobSR Posted March 6, 2019 Share Posted March 6, 2019 Id avoid an Atom on a boosted car personally if you can, only has open loop boost control so very limited. Like you say you then dont' have much I/O either but it does work. You can use a switch type, open/closed TPS as the main load axis is MAP, however again, its not recommended as the majority of the other strategies work of TPS %, so you really want to change to a variable TPS. Quote Link to post Share on other sites
Bolts Posted March 6, 2019 Author Share Posted March 6, 2019 What tps would you recommend any straight bolt up Quote Link to post Share on other sites
RobSR Posted March 6, 2019 Share Posted March 6, 2019 The skyline one Ryan mentioned above does. Quote Link to post Share on other sites
Ryan.Truesdale Posted March 6, 2019 Share Posted March 6, 2019 (edited) On 3/6/2019 at 11:13 AM, Bolts said: What tps would you recommend any straight bolt up Expand page 3 Simple modification to fit skyline rb spec 1 tps its a % tps On 3/6/2019 at 11:03 AM, RobSR said: Id avoid an Atom on a boosted car personally if you can, only has open loop boost control so very limited. Like you say you then dont' have much I/O either but it does work. You can use a switch type, open/closed TPS as the main load axis is MAP, however again, its not recommended as the majority of the other strategies work of TPS %, so you really want to change to a variable TPS. Expand i agree if you want to spend the cash certainly go for the other ecus. just depends what you want Cars.... everything comes down to money Edited March 6, 2019 by Ryan.Truesdale Quote Link to post Share on other sites
Bolts Posted March 6, 2019 Author Share Posted March 6, 2019 Great thanks for the info with that tps what's the go with the wires out the top do you use them or the tps main part Quote Link to post Share on other sites
Ryan.Truesdale Posted March 7, 2019 Share Posted March 7, 2019 On 3/6/2019 at 7:57 PM, Bolts said: Great thanks for the info with that tps what's the go with the wires out the top do you use them or the tps main part Expand you use the part with the wires the other plug is for the automatic gearbox in the skyline this is the one you want make sure its a spec 1 i have more information saved on my phone ill pm you my number message me on whatsapp Quote Link to post Share on other sites
Djaniero Posted March 30, 2021 Share Posted March 30, 2021 Thread Revival: Sorry still new to the standalone game. Do you need a plug and play harness for the links to work on an ep82, or can they be hard wired in? Quote Link to post Share on other sites
daniel_g Posted March 30, 2021 Share Posted March 30, 2021 You get the Link A and B harness depending on the unit it might just be the A for the monsoon, then that gets wired into your loom or get a new engine bay loom made. Quote Link to post Share on other sites
