keithfa26 Posted March 5, 2019 Posted March 5, 2019 Gearbox (Manual) Clutch (pressure plate and clutch disc) Flywheel Flywheel bolts (shorter than the auto ones) Clutch Master Cylinder (the bit with the resivoir on it) Clutch Slave Cylinder (the bit that bolts onto the gearbox) Clutch Lines (both metal line and rubber line) Clutch Pedal Assembly Brake Pedal Assembly Shifter Assembly Shifter cables Both mounts Gearbox needs too be in good condition with no crunching ect! Thanks
keithfa26 Posted March 6, 2019 Author Posted March 6, 2019 anyone know if the Auto drive shafts fit manual?
keithfa26 Posted March 6, 2019 Author Posted March 6, 2019 Can get a ep82 gearbox and everything else listed but will it all fit the same? Flywheel ect?
gwtaylor Posted March 7, 2019 Posted March 7, 2019 I'm in NE and breaking a manual EP82 and have everything you need bud
keithfa26 Posted March 7, 2019 Author Posted March 7, 2019 59 minutes ago, gwtaylor said: I'm in NE and breaking a manual EP82 and have everything you need bud Already talking too you on Facebook mate, just waiting for someone too let me know if all parts fit
