batbo Posted May 28, 2019 Posted May 28, 2019 (edited) I'm looking to fit an ABS delete kit which I'm buying second hand so wont have how to instructions etc. I was just wondering if it's easy enough to fit with the engine in? Most installation threads I've seen are people doing it whilst the bay is empty. Edited May 28, 2019 by batbo Title Updated Quote
garbs Posted May 28, 2019 Posted May 28, 2019 3 hours ago, akyakapotter said: sent you an email bud. cheers nick. Could you send me that email as well please? Also have a kit that needs fitting. Thank you. Quote
batbo Posted May 30, 2019 Author Posted May 30, 2019 On 5/28/2019 at 2:57 PM, akyakapotter said: sent you an email bud. cheers nick. Thanks again Nick much appreciated. I was wondering once the ABS delete kit is fitted can you remove the sensors which are connected to the hubs? Also does it bring up a check engine light on the dash? Cheers. Quote
JamesD89 Posted May 30, 2019 Posted May 30, 2019 The Abs light will come on once it's removed, you can just remove the bulb. Quote
akyakapotter Posted May 30, 2019 Posted May 30, 2019 You have to remove the sensors or will fail mot also remove the bulb for the abs. Quote
