  • 2 weeks later...
  • 3 months later...
Here's some of my other fav pics along the way!
Any comments welcome!
Spec
Engine:
Blitz Access ECU
CT9 Hybrid Garrett Turbo
Blitz LM Front Mount Intercooler
Speed Vision Decat
RS*R Exmag GT Exhaust
RoadRunner Manifold
HKS Actuator @ 1bar
HKS Mushroom filter
Magnecor 8.5mm Leads
NGK grade7 SparkPlugs
TurboSmart Wastegate bleed valve
TurboSmart Fuel Cut Defender
Sard Fuel Pressure Regulator
Samco Rad hose kit
Samco hoses
Custom Rocker Cover
ToyTuning reservoir covers
TRD oil cap
Clutch/Brakes:
3G 10groove Discs and 1144 mintex pads
Exedy Organic Clutch
Chassis:
D2 Coilovers
e'l Sport C Pillar Brace
Cusco Rear Strut Brace
Interior:
Integra Type-R (dc2) Recaros
1x Bride Subframe
1x Recaro Subframe
Rear Fully Stripped
Defi Gauges, Turbo, Water Temp and Control Unit
HID headlights
Exterior
Buddyclub P1 Racing Alloys
98Spec Front Splitter and Rear Bumper Extension
Front Bumper Modified for FMIC
Number plate relocated (scraping the barrel now?!)
That last pic if cool as fook! Lovely clean Glanza mate.
Could I ask? How difficult/easy were those Recaro's fitting into the car? Did you have to adapt the frames at all? Its just I have now hopefully got some and was wondering how hard they would be to fit.
if you get the right rails then it bolts straight on, i've just sourced my own bride rail and bride seat for the generous total of £54 (for both, not for a starlet by the way as starlet rails as rather expensive compared to others), and they mated together first time no worries, but there are so many different rails about that you must ensure that it is the correct model.
