nathy boy Posted May 3, 2008 Posted May 3, 2008 Right i have a problem wondered if anyone can shed any light,i fitted a de-cat about 2 months ago and did away with the o2 sensor, in the past two weeks its started to smoke a fair bit on tickover usually when its warmed up when im driving it doesn't smoke from what i can see. And its just pissing me off because im too proud of my car for people behind me at traffic lights or car parks to think its fucked. So my question is what does the o2 sensor actually monitors and does and could this be the problem or could it be something else?Thanks in advance. Quote
keirz Posted May 3, 2008 Posted May 3, 2008 first off change your pcv valve. it may be a little blocked causing an engine breather problem. if that doesnt work then maybe a bit of oil is getting past your oil deflector or shaft piston ring in your turbo. you wouldnt have had the smoke before as the cat would have been stopping most of it.if the 02 sensor is the bottom one of the two on the decat, im not running with it either and have no smoke. Quote
paul w Posted May 3, 2008 Posted May 3, 2008 As above,turbo on it's way out. Easy to fix for now,just put the cat back on to absorb the oily smoke till a replacement turbo can be sourced. Quote
keirz Posted May 4, 2008 Posted May 4, 2008 check the pvc valve first though as it can easily cause an exhaust to smoke. Quote
StarletRick Posted May 4, 2008 Posted May 4, 2008 you completely removed the O2? that was silly. get it put back in now. your car will run shit without it. Quote
keirz Posted May 4, 2008 Posted May 4, 2008 is o2 the top or bottom of the two on decat rick? im assuming top, as the bottom one is just a cat temp sensor right? and not needed. Quote
nathy boy Posted May 4, 2008 Author Posted May 4, 2008 The top is the lamba sensor and the bottom is the o2 if im correct and not getting confused here? I need to find a reducer to fit the o2 sensor back in at the bottom (cant remember what size thread the sensor is). It doesnt appear to be oily smoke though it appears to be running rich and not burning all the fuel. Quote
keirz Posted May 4, 2008 Posted May 4, 2008 well im not running with the bottom sensor. im sure its not important and was told by many people its not needed. also my car is running fine with no issues or smoke. Quote
paul w Posted May 4, 2008 Posted May 4, 2008 The top is the lamba sensor and the bottom is the o2 if im correct and not getting confused here? I need to find a reducer to fit the o2 sensor back in at the bottom (cant remember what size thread the sensor is). It doesnt appear to be oily smoke though it appears to be running rich and not burning all the fuel.What colour is the smoke?Does it smell? Quote
nathy boy Posted May 4, 2008 Author Posted May 4, 2008 Its like a grey colour not as black as it would be if it was burning oil. It doesnt smell like oil either. Quote
