i aquired it from a japanese breakers close by..
they come on any ee111 corolla 4efe.
i think it makes the engine rev more freely now.
cheers guys
<{POST_SNAPBACK}>
Just on that note, the stock one will fit but you need to move the fuel filter lower to clear the bar, will take you about 20 minutes to complete.
Regards,
Ivan
  • 4 weeks later...
you will only realy feal the effects of a sturt brace if your car is lowered or has stiff suspension.
my car is slammed.
before i fitted my strut brace, over uneven and offcamber corners the car felt nervus and unplanted.
after fiting it the car felt alot more sure footed and felt like it could hold more speed into corners and over those ruff surfaces..
I would like to ask what`s your opinion concerning cuscos type os vs whiteline`s strut brace (front strut braces). Both are alloy but whiteline`s is adjustable also. Which one do you believe its better and will be any difference?
i think when it comes down to strut braces they all do the same job so there is no real advantage over any brand unless your into saving weight.
dam manic!
your spunkin alot of money into your car..cool as f*ck.
what other plans do you have?
  • 3 weeks later...
i actualy just bolted the strut brace on. its a tight fit, bet everythings fine
the fual filter does touch slightly but there is no presure on it.
