anyone fitted an exhaust manifold without moving the turbo or rad at all?
is it possible to
*remove efi pipe
*remove heatsheild
* unbolt 4 nuts from mani to turbo
*unbolt mani from block
will it be possible to just do this or will there be no angle to remove the mani? im hoping to do it without removing rad too. i know im changing my turbo soon anyway but was just gonna whack my mani on some time this week if its an easy enough job.
i know the efi pipe and getting at a few of the bolts is a pain, but is it impossible to do with the turbo in place?
You wont get to the nuts at the back of a standard mani.
You will be much quicker and easier to take it all off,can be done in an hour and a half, if it's your first time it will take longer due to seized mani nuts etc. Get the nuts soaked in penetrating fluid at least overnight.
The only ones on mine that were really stiff were the turbo studs to the manifold.
But if you can get the manifold and turbo off in one, you can clamp the manifold in a vice and use a massive spanner on them.
WD40 works well.
  • 1 month later...
  • 3 weeks later...
