Evening Guys,
Not sure if this is the right section so il apologise now if it is :D.
Can anyone tell me what bulbs the ep91 takes? As im after fitting HID's but unsure on bulb fitment?
Regards
Rob
  • 2 weeks later...
also u wna consider that starlet (n/a and turbo) are negatively wired in the lighting department, so u may have probs fitting them
i had to get mine modded to work because i could not get hi beam!
^ yup H4...you dont need HI/LOW ones its personal pref...also yeah, you have to reverse the polarity i beleive..
i installed my H.I.D. kit without any probs, didn't have to change polarity at all.
My hid kit takes power straight from the battery and has 2 grounding wires, so maybe it works different to ther hids.
  • 2 weeks later...
Evening Guys,
Not sure if this is the right section so il apologise now if it is :p .
Regards
Rob
Hi there guy's just wanted to know about the HID installation wanted to install them in the foglights when i get my car and i just wanted to know what kind of bulbs do the foglights use? so that i can see if i could install them in my foglights?
Thanks in advance
Tha Dragon
what and just run on fool beem all the tine???
