Pretty much as the topic title says, im undecided so whats the pro's and con's of each..
Im swaying towards the front mounted to be honest..
Also, have i seen a hks front mounted on a glanza before?
depends what you want it for??
if your sticking with a mildly tuned ct9 powered engine then the arc would be the easiest and probably best option.
if you planning on going anywhere near 1 bar on a ct9, or going for a turbo conversion then you will need a fmic
im going to stick with the ct9 and take it as higher boost as i can, my plan is a 04l conversion but thats why im looking at front mounted, i want it for the strip mainly..as well as some trackdays
And go for a wepr or petbeemer kit, Blitz and HKS fmic's are extremely expensive, and for what you need are not really needed. A blitz fmic and exhaust cost more new than my 94 GT with lsd lol!!!
Both the wepr and petbeemer kits are around £300 all in, and will probably actually do a better job than the blitz/hks with ct9 as are smaller, which is what you need for a ct9, td04 etc. You don't want a massive one..
Tobs
different leagues mate...
the arc's are for mild tuning, maybe something like a self learning sard/jam ecu upgrade, probably good for upto 170bhp (at a random guess, we'll see how far i can take mine...) but a fmic is a different league. even with a small fmic you're good for 250bhp, but as said, its horses for courses.
fmic is alot of effort and pipework, also a big draw of attention, so it all depends on what you're after.
i'm biased obviously, but the arc's are mint, but they're also stupidly expensive. i do not know what bhp they're good for, but i'll source an ecu, up boost, and see how far mine will go before it becomes the limiting factor.
Guest daveburwash
fmic is alot of effort and pipeword, also a big draw of attention, so it all depends on what you're after.
<{POST_SNAPBACK}>
You can't even compare a decent FMIC with a top mount interwarmer!! :huh:
i dont like the idea of the extra lag you get with front mount,
but then i dont like the interwarmer idea either, heat soak really spoils the fun.
if front mount wasnt so expensive i would go for one, is it cheaper to buy a starlet specific kit, or get one custom fitted?
and what about insurance, front mount can be so obvious and if you dont declare insurance your screwed!
<{POST_SNAPBACK}>
yes dave, hence why i said they're COMPLETELY different things, well, actually i said the fmic's are a 'completely different league', if you think i was comparing them then please feel free to read what i wrote as much as you like, i dont think i could've explained it much clearer.
The arc tmic works a treat if you're only going for mild mods, and makes a very simple and easy upgrade from the stock one, but as soon as you wanna get serious with the mods the only way forward is a fmic.
i dont know what they're good for bhp wise, but i'm willing to try and find out. ;)
if its a limiting factor earlier on, then FMIC will be going straight on.
:edit: sorry if that sounded sarcy dave, didnt mean it to sound like i was getting funny or anything, was just trying to explain what i'd said. ;)
Guest daveburwash
No not meant like that at all
ah ok sound dave, ye i didn't wanna sound like i was comparing the two, because the differences are obvious, but the little arc does have its good points.
the top mount as a component is a highly underated piece of kit,
does anyone know where to purchase one of these arc top mounts?
new, about £700, from somewhere like new zealand.
used, you'll have to keep your eye out on ebay and such, because they're rare for a reason. :huh:
i know where one is, but its got a little damage and is currently in japan.
im aiming towards 200+ so i think i might just save my self the hassle and money and go straight for a fmic.. allthough im not happy about the lag itll produce with the longer hardpipes , what fmic kits you guys using ? im currently saving for a blitz but the wepr's look quality..
have any of you considered a chargecooler? as in, water cooled?
not as laggy as a fmic and apparently have cooler inlet temps?
sounds like the best of both worlds to me?
I allready have a fmic aqua mist kit sitting in the spare room so that should bring charge inlet temps down a bit when i fit one. by the way seeing as theres alot of people viewing this thread, do any of you guys/gals know if rota make any wheels with a blue anodised lip instead of there usual red lips? or any decent uk suppliers of advan or volk/rays ? links also would be usefull :huh:
I know, all these questions im being a bit cheeky ;)
for volks rays your best bet is to do a search in google its what i did when i wanted a set, there are loadsa companies on there, i used funkyproduct in the end, or uv got sumo power and many others
like an intercooler but with water lines going in lol google it :huh:
Sumo power charge a bit extra for than other companys so ill pass with them, saw a nice set on ebay actually in 15" which is pretty rare for volks 2nd hand, immaculate white ones but there foookin 5stud ;)
without doubt the best option if response is everything to you,
keeping lag to a minimum,
adding a seperate oil cooler will work wanders for engine longevity...
