Asad Posted August 23, 2008 Posted August 23, 2008 hey had my starlet since may....when i got it it used to shake alot when left idling e.g. at the lights not really full on shaking but noticeable little movements the shaking went with the engine beat...the needle is always moving not at one point like all/most cars. after two bottles of redex improved alot...but it still shakes and the needles still doesn`t sit still always ossilating aroung 750-1000 rpm. my suspision is the fuel filter as i dont think it has ever been changed..has service history to an extent then was serviced by the same garage for the next 5-6yrs...the fuel filter looks new and genuine....lambda has been replaced fuel economy isnt the best on the car either (i have put on the corolla mani if it helps)..starts first time without fail in the morning tho. i am puzzled dont know where to begin. Quote
ste91 Posted August 23, 2008 Posted August 23, 2008 When did it last have a full service, including oil change, all of the ignition parts, and air filter?My guess is that it hasn't been serviced and is not running very well. The shaking could also be caused by dodgy engine mounts.But since you said the needle moves up and down it's probably the engine.Check all the sensors are ok, and everything is connected. Quote
briggers Posted August 23, 2008 Posted August 23, 2008 my girlfriendsdoes this but you cant notice the needle move it just judders at the lights now and again. but then again the engine is fooked we think as we can hear nocking and also it smokes now and again so we think its piston rings. Quote
paul w Posted August 23, 2008 Posted August 23, 2008 Could be crap battery/altenator not charging properly. Quote
Asad Posted August 23, 2008 Author Posted August 23, 2008 it had oil (10w 40), oil filter,air filter, plugs, clutch, timming belt at the same time...me n my dad did it. as for the battery and altnator...the main symtom would be not starting but it starts first time all the time. again my suspision falls on fuel filter or injectors. Quote
WallaceGlanza Posted August 23, 2008 Posted August 23, 2008 Probably just need to clean the idle valve, lots of starlets hunt on idle. Quote
Asad Posted August 23, 2008 Author Posted August 23, 2008 is that the "disc" thing inside the throttle body? Quote
ecksjay Posted August 23, 2008 Posted August 23, 2008 no.check the plugs, make sure they're installed correctly (after you get some new ones). Quote
Asad Posted August 23, 2008 Author Posted August 23, 2008 they are new only done a few hundred miles...ill chek if they are tight etc tho Quote
ecksjay Posted August 23, 2008 Posted August 23, 2008 well it may be that they are overtightened, they should ideally be torqued or at least by someone who knows 100% what they're doing with them. Quote
Asad Posted August 23, 2008 Author Posted August 23, 2008 erm ok......what makes u think it is solely the spark plugs? Quote
ste91 Posted August 23, 2008 Posted August 23, 2008 I've had no trouble with my plugs and I just tightened them until I felt they were tight enough Quote
Asad Posted August 23, 2008 Author Posted August 23, 2008 same here ive been doing that since i was about 11. worked on many cars while growing up had none complain because of overtightened spark plugs when they come back for other work Quote
Hairy1 Posted August 23, 2008 Posted August 23, 2008 hey had my starlet since may....when i got it it used to shake alot when left idling e.g. at the lights not really full on shaking but noticeable little movements the shaking went with the engine beat...the needle is always moving not at one point like all/most cars. after two bottles of redex improved alot...but it still shakes and the needles still doesn`t sit still always ossilating aroung 750-1000 rpm. my suspision is the fuel filter as i dont think it has ever been changed..has service history to an extent then was serviced by the same garage for the next 5-6yrs...the fuel filter looks new and genuine....lambda has been replaced fuel economy isnt the best on the car either (i have put on the corolla mani if it helps)..starts first time without fail in the morning tho. i am puzzled dont know where to begin.my sypathies man, my n/a judders now and then when i pull away and used to have a noisy idle,i ran the tank as low as i dared then changed the fuel filter (do the bastard up tight) then swithed from cheapo 95 octane to v-power 97 octane its alot quieter at tickover since-just try switching the fuel but u need to have it near empty before tho, let us know if it helps Quote
Asad Posted August 23, 2008 Author Posted August 23, 2008 tbh mate the shaking isnt BAD but quite small and v noticable. what i propose to do isclean the throttle body when i replaced the mani it looked dirty but i dint have time to clean it.check spark plugs tighten them or loosen them which ever is appropriate, and look at the colour (would tell me alot if something was wrong)replace the fuel filter with a genuine one (eliminates the filter if it continues to shake)and hope for the best.... Quote
