Well when i got my 97' glanza v it was pretty much standard with just a HKS exhaust system, Team Dynamic wheels and Trust panel filter.
As most of you know it never stays like that, you get bitten by the power bug so start modding. First to come was a HKS actuator a couple of gauges, de-cat, Blitz bov and K&N induction kit.
A few months later i won a show and shine at a big jap show (rising sun car show). This really spurred me on to to more!
We sold our skyline my other pride and joy and suddenly i had money burning a hole in my pocket!!
One drunken afternoon me, dave and my mate took the engine out of the car (like you do!!) as i had plans-Now there was no going back..
I decided to go TD04 with forged internals. I was soon on the phone with Dave Burwash and messaging Sacha for parts. I decided on Sacha's (wepr) TD04 kit.
We sent the block off to be bored and the head off for:
New valve seals
Head skimming
Valves pressure tested and reseated
Tappets shimmed
Valve clearences set
We then started with the rebuild.
I decided to replace almost everything as didnt want to leave anything to chance:
Water pump
Oil pump
Big end bearings
Thrust Bearings
Main Bearings
Thermostat
All belts
Full toyota engine gasket kit
All rubber hoses for silicone hoses.
After the rebuild came a painfull running in period (1000 miles) and 4 oil changes.
Now my current spec is:
wepr manifold
td04 turbo
tial external wastegate
wepr front mount intercooler
screamer pipe
wepr decat
blitz supersound bov
hks exhaust system
7mm ultra leads
wiseco 74.5 forged pistons
scat forged conrods
full engine rebuild
ngk iridium heat 8 spark plugs
walbro fuel pump
550cc sard injectors
zep racing 1.2mm headgasket
greddy profec e-01
apexi air filter relocated
emanage blue
cap 4 paddle clutch
Subaru WRX 2006 seats
Oil pressure/Water temp/Boost gauges
After a full remap and fitting of e-manage Blue at Fusion Motorsport (by ed) i had it rolling roaded at Sussex Rolling Road and got the following results:
This is my car now. Id say finished but im sure i will find something else to buy!!
  • Replies 61
  • Created
  • Last Reply
Top Posters In This Topic
Love this car!!!
Pretty much the set up I plan on going for!!
Awsome work there, was the polished rocker cover hard to do?
cheers
Yeah it took ages!!! real hard work but worth it i think!!
rach
cheers guys!
its mapped to 1.4 bar.
they are subaru 2006 wrx seats
and the thing on the steering wheel is a remote for the e-01 boost controller so you can up boost for better traction when setting off. i dont really use it to be honest although it is pretty good!
rach
What did you use on the rocker to get it like that?
Want to make a start on mine lol
Good results its not a hybrid td04 kit is it?
no not a hybrid..
i used meguires metal polish and a polishing mop on a drill. took alot of patience
rach
How hard were the seats to fit mate?
they weren't easy to be honest. had to make brackets and have them welded on and it was hard to line the runners up.
they were def worth it tho as they have so much more support than the standard ones!
rach
very clean man, that was one drunken session lol good on ya
it certainly was, my mates couldn't believe what we had done!!
especially as we had not done nothing like that before, you've got to have a go though havent you.. :lol:
luvly, must be savage to drive.
wheres the diff?
cheers :p
aint got one yet. am planning on one tho!!!
its not too bad to drive its only first gear that is a problem really but i dont go launching it all the time anyways!
What HKS System does this have? Really like the way it angles upwards like a supra.
What subaru where these from(year, model, uk/jdm)
Did the seat & frame bolt straight in?
Got any vids of the tacho wipping to the redline :p
in not sure which hks system it is it just says hks on it..
the seats are from a 2006 wrx and they wernt that easy to fit we had to make brackets and have them welded on then it took ages to line the runners up!! worth it tho.
and i havent got a vid of rev counter but i have got a vid on rolling road not that you can see much!!
^^^^ great vid. luv how the car lifts up from the front when on boost. Great
i no thought it was coming off at one point!! lol
