how do u bleed brakes?
how do u drain brake fluid out of tank n system?
top reservoir up and pump brake whilst friend undoes bleed nipple till no air, check reservoir n do same. starting rear passenger to front driver?
cheers craig
without engine running
make sure resevoir has fluid in at all times
open nipple (amate)
press brake (you)
close nipple (a mate)
off brake (you)
repeat the above untill allmost all air is gone
tighten niple and pump the brakes
open niple there will be a shot of fluid come out and onto your iner arch no doubt
press the peddle slowly whilst tightening the nipple
pretty much it, anyone correct me if ive missed/miss told anything
MAKE SURE NO FLUID GETS ON PAINTWORK its works as a sort of pait stripper
  DavidAshton said:
Are you supposed to do it with the engine off? Last time i did it with it on, does it make a difference?
Braking is assisted with the engine on
Put a cube block of wood under so the pedal doesnt go down far-far i think it damages the seals of the mater cylinder.
  • 2 weeks later...
  • 1 month later...
