string Posted November 6, 2008 Share Posted November 6, 2008 how do u bleed brakes?how do u drain brake fluid out of tank n system?top reservoir up and pump brake whilst friend undoes bleed nipple till no air, check reservoir n do same. starting rear passenger to front driver?cheers craig Quote Link to post Share on other sites
Driver Posted November 7, 2008 Share Posted November 7, 2008 without engine runningmake sure resevoir has fluid in at all timesopen nipple (amate)press brake (you)close nipple (a mate)off brake (you)repeat the above untill allmost all air is gonetighten niple and pump the brakesopen niple there will be a shot of fluid come out and onto your iner arch no doubtpress the peddle slowly whilst tightening the nipplepretty much it, anyone correct me if ive missed/miss told anythingMAKE SURE NO FLUID GETS ON PAINTWORK its works as a sort of pait stripper Quote Link to post Share on other sites
DavidAshton Posted November 7, 2008 Share Posted November 7, 2008 Are you supposed to do it with the engine off? Last time i did it with it on, does it make a difference? Quote Link to post Share on other sites
ste91 Posted November 7, 2008 Share Posted November 7, 2008 Are you supposed to do it with the engine off? Last time i did it with it on, does it make a difference?Braking is assisted with the engine on Quote Link to post Share on other sites
DavidAshton Posted November 7, 2008 Share Posted November 7, 2008 Braking is assisted with the engine onSo you supposed to have it off then? Quote Link to post Share on other sites
ste91 Posted November 7, 2008 Share Posted November 7, 2008 no idea I don't have a clue about brakes really all I know is that while the engine is running braking is assisted Quote Link to post Share on other sites
Asad Posted November 7, 2008 Share Posted November 7, 2008 Put a cube block of wood under so the pedal doesnt go down far-far i think it damages the seals of the mater cylinder. Quote Link to post Share on other sites
Tintin_SR Posted November 9, 2008 Share Posted November 9, 2008 So you supposed to have it off then?do it with the engine off buddy Quote Link to post Share on other sites
Sparky Posted November 11, 2008 Share Posted November 11, 2008 Was going to say I have never bled the brakes on any car with the engine running Quote Link to post Share on other sites
Glanza_Ragger Posted November 11, 2008 Share Posted November 11, 2008 Dont bleed brakes with the engine running.Start at the corner furthest from the resevoir, moving to the front closest to it. Quote Link to post Share on other sites
glanza87 Posted November 26, 2008 Share Posted November 26, 2008 I agree with ragger lol Quote Link to post Share on other sites
Kennedy Posted January 7, 2009 Share Posted January 7, 2009 never done this before so might b a stupid question...how does the nipple open? does it just unscrew? Quote Link to post Share on other sites
Bourkey Posted January 7, 2009 Share Posted January 7, 2009 Here is a good video for you all. It's how i learned years ago.Good VideoBourkey Quote Link to post Share on other sites
Kennedy Posted January 8, 2009 Share Posted January 8, 2009 Thanks Bourkey..helps alot Quote Link to post Share on other sites
