tyres
oil
everything under the bonnet
Look for any sort of painted writing (scrap yards write things in paint, check to see whats been replaced and find out why)
make sure the battery isnt loose
check for damage
make sure theres no rust
engine temp on the dial
make sure it idles fine
check clutch
make sure it drives fine
listen for rattles and knocking noises
get on ya stomach and look under the car
check the steering
all the electrics
check the engine code and frame number to the V5, also look at all paperwork
listen for exhaust blowing
make sure any aftermarket parts listed on it, are on the car, working and fitted properly
takes a while, but make sure you do it bud. otherwise you may regret buying it.
Another point to note, actually stand back and have a look at the car from a distance...miss aligned body panels, diff height at rhs compared to lhs etc.
try to look at the car at different angles with the light coming from the same way to spot differences in colours tht suggests a paint job (especially on the front wings) other than tht everything as above
Yup, view during the day and take as many people as you want!! if there something wrong atleast 1 of you may spot it.....if anything minor/fixable is wrong dont walk away asap haggle n get the price down using the problem to your advantage good luck
oh and take lots of pics for us! :lol:
just picked her up there
from yorkshire,was mint to see my red starelt and the gt together driving back up :lol:
only 1 thing wats dodgy the heater doesnt heat up 2 warm iside the car :) any 1 kno what the problem could be??
part from that perfect!
ohh u kno when you turn the engine off and then back on it makes like little rev sounds thats kooling the turbo down isnt it?
totally standard as well gt 1995 quadlight
Yup....^ dipstick thing going on for the gear box oil?
shes a beaut mate.....heater matrix? thermostat? needs a coolant flush?
by the way mate.....you need to get them skirts bought up frm swt.... :lol:
how do i do a coolant flush mate? is that y my heaters not working?
Looks pretty damn clean and standard!!
Is it an auto?
it sure is bud
drove it before gooooooooooooooooooooooood the power is amazinggggggg compared to the n/a
feeels klasss
bet your looking faward to getting urs now :lol:
do you kno y it revs wen stoped then is that kooling the turbo down or sumthing?
It could be loads of reasons why it isn`t working....drain the rad via the tap at the bottom, open the hoses etc flush with the water hose dont forget the coolant bottle.....you may aswell replace the thermostat while your at it save headache later and rules it out for any problems.
Then if it still isn`t working it would the heater matrix/the controls inside.
If they totaly dont come on, then its the controls
cheers mate
weres the thermostat by the way, i rang the guy and he said he thinks its that.
£10-16...+ another £5-10 for antifreeze its about a 45min-1hr job tops :lol:
lol nice numberplate, you need a big turbo on it now :lol:
And how come you went for an auto? Your N/A is auto aswell isn't it?
