What is your boost gauge measured in?
14 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
If you like small numbers get one that measures in BAR, if you like big numbers get one that measures in PSI, doesn't really make any difference whatsoever.
mine's in bar, which i dont mind. i know how much psi relates to bar, so dont mind which.
starbo's dont run a huge amount of boost so it doesn't really matter either way to me. :rolleyes:
Guest Enzo
idgetpsi and a/f ratio if i had two slots to fill bud
If their both measuring the same thing, can't you have one gauge with BAR and PSI labeled on it? (like MPH / Km/H on your speedo?)
Suppose you could, but 1BAR=14.5PSI so the two scales on the one gauge would be a bit messy. Some of the cheaper gauges have both on the one scale.
