I'd say mor ethan likely CV joint but be careful cus i though that it turns out it is but its inner Cv so is munching chunks out of my box and generally not very nice
many thanks i wil see what i can do
Guest dominodon
had this befor it was the brake line hose holder nocking on the side wheel arch
jack the car up do a full lock and see it anythink in touching rember to use stand's to hold the car up
  • 2 weeks later...
If u have a ramp available it won't be hard to replace them.
U could find a set 2nd hand driveshafsts and replace the complete shaft, saves u alot of hassle :p
and if it's knocking when turning to the right, then it's the left cv joint :p
