Look at me trying to work out all the conversions first Km to Miles now Psi to Bar
Right fianlly had my Boost guage fitted read otu is in Psi
thought standar boost should be running around the 10psi mark mine ehtier seems to be over boostign or the gauge is inaccurate.
The gaug is wired to the manifold i belive and reads 18psi in fith gear foot flat to the floor and in all other gears reads a staedy 15psi
Want to no what bar ratign that is pelase :-D tried googlign it but had no luck
see it should only boost to 10psi as i thought. But it cant be over boosting double can it doesnt feel like its running 1.2bar
possibley not that im aware of.
The car is basically standard standard top mount just got a ss exhaust i did hit fuel cut earlia on the motor way. Doesnt feel like 1bar atal tho
My old autogauge boost gauge would over-read loads, especially when running about 1 bar, sometimes it would shoot to a reading of 20psi, which was wrong!
If your gauge is a cheapo one, Id upgrade that first with a decent one (ie greddy, apexi, blitz)
The gauge is fine its a prosport one cost me £110 better had be good lol
Worked it out just needed reconnecting. boost's to about 10psi until 5th gear
14.5 Psi - 1Bar
Its actually 14.7psi to a 1 bar :D
My Defi reads just over 1 bar before it fuel cuts which obviously aint right.
Would it be because its T'd into the dump valve vacuum line and not on its own?
Sparky.... you are fail....
14.50377439 psi to 1 Bar
I work with pressurised equipment accross the world :D I know what the conversion rate is :)
im an aircraft engineer and this is correct!! :D:D:p
