SiCaln Posted May 23, 2006 Posted May 23, 2006 As most of you will know i have a white set of 15" TE37's that desperately need to go on my car, now i have put Toyo T1R tyres on em and they have been inflated thru nice blue Rays valves, but there is one snag to fitting 'em.I cant get the right sized spigot rings that will mate my hub to the back of my wheels, can anyone shed any light on where i could get some??? PLEASE Quote
scutch0 Posted May 23, 2006 Posted May 23, 2006 i never used spigot rings on my wheels???are we talking about the same part? the plastic ring that you attach to the wheel so you can put the wheels on the hub before putting the bolts in?if so ive never needed them! Quote
scutch0 Posted May 23, 2006 Posted May 23, 2006 yeah, just looked it up... never used spigot rings with my wheels before... but after looking at the problems when you dont have them, i may have to get some!!! Quote
SiCaln Posted May 23, 2006 Author Posted May 23, 2006 yea that was my thoughts when they cost that much to buy its worth it Quote
scutch0 Posted May 23, 2006 Posted May 23, 2006 i genuinely didnt know what they were really for... never sa any use for them??!! hmmmmm maybe i'll be getting a set!Rich. Quote
Shaun Posted May 23, 2006 Posted May 23, 2006 all they do is take the inbalence out of the wheel over wise the wheel might not be bolted to the hub level if its not you will get problems like wheel bearings going and things like tyre wear so get some if you can Quote
scutch0 Posted May 24, 2006 Posted May 24, 2006 what if you dont have them on? but need them.<{POST_SNAPBACK}>all they do is take the inbalence out of the wheel over wise the wheel might not be bolted to the hub level if its not you will get problems like wheel bearings going and things like tyre were so get some if you can<{POST_SNAPBACK}>How can i tell if i need them?Sparky<{POST_SNAPBACK}>look like were all in the dark here...look here-> http://www.planetsoarer.com/offset/studs.htmi wont be driving so hard from now on until i get some!Rich. Quote
miracle411 Posted May 24, 2006 Posted May 24, 2006 When i get my rims they came with the set, i thought they were just spacers to be honest, try contacting Larkspeed as they supplied mine for me. They should fit the same i would've thought. I acutally had mine on the wrong way round at first and all my wheels wobbled like crazy so maybe its worth fitting some. Laters. Quote
Sparky Posted May 24, 2006 Posted May 24, 2006 Wow that really has made me paranoid about pushing it now.But how can i tell if my wheels havnt got the right size spigot? I have a feeling they might be the right size though......I hope Quote
SiCaln Posted May 25, 2006 Author Posted May 25, 2006 see if your wheel wobbles at high speed and if theres movement on the top and bottom of the wheel Quote
lobotomy Posted May 25, 2006 Posted May 25, 2006 Never read that whole page (sorry not in the mood - just in from work)But does that just mean you need spigot rings for multi-fitment wheels? Quote
StarletSi Posted May 25, 2006 Posted May 25, 2006 I have multifitment wheels and I got em with the wheels Quote
Shaun Posted May 25, 2006 Posted May 25, 2006 only if your wheels dont have the right senter boremine are fine as they r made for the car Quote
