Hey all,
Just remembered about this forum (havent posted since 06) so thought I'd say hi.
I'm from New Zealand and have a EP71
Cheers
Stu
hi Stu the site would have changed quite a bit, hope you like the imporvements.
if you can be arsed you should get a few pics of your car up maybe in the rides section, if its that blue one from memory i think the spec is insane,
Haha dunno about insane but I'll appreciate any feedback :lol:
Just about to put the new engine in which should produce a fair bit more power.
Wowee, Bonkers, 4AGTE is insane, IIRC thats a mix match of engines, its not a standard Toyota engine.. is it?
Look forward to the specs :lol:
The 4AGZE (supercharged) is well suited for boost. So yeah you're right it's not a standard Toyota engine, it's got a turbo instead. Another possibility is a 20v head.
Thanks guys.
The old setup was basically a standard AW11 4agze engine with a TO4e turbo, Linkplus ecu etc and made 196kw at the wheels on 16psi.
This time around its a bit more serious with a built bottom end, extensively worked on blacktop head, custom inlet, plus a heap of other changes. Going to really lean on this setup and try to produce some reasonable numbers.
Will post up photos and full spec when its finished in a month or twos time.
