Dave L-W Posted May 11, 2009 Posted May 11, 2009 1) My tyres are rubbing my arches. Would new springs solve it because nobody else on here seems to complain about the same problem.Any recommendations on what springs?Tein?2) I have desmond regamasters on my car aswel and they are flaking does anybody have any ideas on what colour would look good?(my ep82 is metallic black) I do NOT want to sell the wheels as i think they are top s***!3) Would i have to have a screamer pipe custom made my a44 on worcestor or can you buy them from anywhere?If anybody could help me I would be very appreciative because these things are starting to Piss me off abit! Quote
Galliano Posted May 11, 2009 Posted May 11, 2009 1) Not sure2) If you want something over the top and JDM.. Orange? Or red? If not then black, white, silver or a gunmetal grey.3) Not sureSorry im not much help Quote
Idrees Posted May 11, 2009 Posted May 11, 2009 1) Your wheels could be the wrong offset, you might want to check them mate. Starlets should have 37-40 off set.If they are too low, for example ET35, they will catch your arches because they stick out too much. So the best way to cure the problem is by getting your arches rolled. Quote
Dave L-W Posted May 11, 2009 Author Posted May 11, 2009 So you don't think its because the springs are knackered?because at the top of the coils there are no gaps between them as if they have sagged and need replacing.I don't really want to roll the arches really. The tyres are well inside the body though so i dont think that is is the spacing.Cheers guys i really want to get this sorted because its ruining the fun of driving! Quote
Dave L-W Posted May 11, 2009 Author Posted May 11, 2009 Is the car really low on them springs?if i knew how to put a pick up i would!how do i do it? Quote
ToyotaTech15 Posted May 11, 2009 Posted May 11, 2009 Upload the pics you want onto photobucket then just copy the image code into the postGary Quote
Dave L-W Posted May 11, 2009 Author Posted May 11, 2009 these are the only pics i have that show the car really Quote
ToyotaTech15 Posted May 11, 2009 Posted May 11, 2009 It does sit quite low,What springs are on it did you say?Gary Quote
Dave L-W Posted May 11, 2009 Author Posted May 11, 2009 It does sit quite low,What springs are on it did you say?Garydont know they've been on it since it was brought over from japan.theyre black wiv an orange mark on them?!?sits nice i think, dont want to compromise the looks really Quote
ToyotaTech15 Posted May 11, 2009 Posted May 11, 2009 Are they rota slipstreams you have on it?They should be the right offset as my rotas are ok,It will probs tell you the offset on the back of the wheelGary Quote
Dave L-W Posted May 11, 2009 Author Posted May 11, 2009 Are they rota slipstreams you have on it?They should be the right offset as my rotas are ok,It will probs tell you the offset on the back of the wheelGaryna they are desmond regamaster evos!theyre quality wheels and F****** expensive! thats y i dont want to get rid of them Quote
ToyotaTech15 Posted May 11, 2009 Posted May 11, 2009 Oh sorry man lol,Maybe worth checking the offset, and if possible checking the spring/shock absorber condition,Check for any leaks or broken springs etc, it seams to sit equal all round thou.Gary Quote
Dave L-W Posted May 11, 2009 Author Posted May 11, 2009 Oh sorry man lol,Maybe worth checking the offset, and if possible checking the spring/shock absorber condition,Check for any leaks or broken springs etc, it seams to sit equal all round thou.Garyyeah im going to get some tein springs anyway just to try my dads mate who has been a mechanic for 40 odd years said that hes never seen springs completely compressed like these and thinks theyre shagged. I just want it sorted yh it sits nice but its destroying my new tyres and makes a horrible noise!!haha Quote
Bluebear Posted May 12, 2009 Posted May 12, 2009 The Rota Slipstreams are actually copies of the Desmond Regamasters Gary Quote
kevink Posted May 12, 2009 Posted May 12, 2009 Does it only rub on the rear? mostly righthand side?Panhard rod is the way to go when you lower a starlet like that. Quote
Sparky Posted May 12, 2009 Posted May 12, 2009 Keep the wheels white looks sexy as fook!!I wouldnt really run a screamer pipe on an internally gated turbo, apparently sounds tractor'ish on idel etc, externally gated FTW Sounds like your springs are shagged mate, I would get a new set but Tein's do not go very low and I love teh stance of your car I would save up for some coilovers Quote
Dave L-W Posted May 12, 2009 Author Posted May 12, 2009 what springs should i get then?And where from? i would get coilovers but money is tight with 3 cars and a girlfriend!haha! Quote
AlexGTAdv Posted May 12, 2009 Posted May 12, 2009 Is it just rubbing on the rear mainly on the right as said before? If so then you will need an adjustable panhard rod!?!? Some lowering springs do come with some of the coils near each other at the top and spaced out in the middle, this is so that it has the same amount of coils as stock springs but will make the car sit lower. So to recap your springs may be ok and you might just need to buy a panhard rod to bring the rear axle back in line as the starlets are shite and have a stupid rear axle that shifts to the right as you go over bumps or if you lower it so this could be your problem. Quote
