Nic's 1997 White Toyota Starlet Ep91
Make: Toyota Starlet
Model: 1997 EP91
Engine: 4efe
Engine Mods:
- Full exhaust system; Pacemaker extractors, High flow cat, 2" cat back, 2" sports muffler with 4 inch tip and 8 inch Barrel
- 4efte intake manifold
- K & N Pod Filter with custom cold air intake (Battery reallocated to driver side)
- NGK Iridium Spark Plugs
- Top gun ignition leads
- Oil catch can with custom made brackets
- High lift cams
- TRD 0.5mm headgasket
- Mild ported 4efte head
- Microtech LT-8 ECU
- 4efte rods
Suspension & Bars:
- TRD coilovers 6kg front 4kg rear
- Starlet GT Front strut bar
- White Line Rear Sway Bar
- White Line Front Sway Bar
- White Line Anti Lift Kits
- Cusco Adjustable Camber Top
- SuperPro Front LCA bushes
Brakes:
- EP82 front caliper
- EP82 rear disc conversion
- Bendix Heavy Duty
- RDA slotted and vented disc
Exterior:
- Toyota Starlet Reflect Front Bar
- DIY Rubber Front lip
- Glanza Wing
- Glanza Sideskirts
- De badged Exterior
Interior:
- Glanza white cluster
- Razo pedals
- Momo gear knob
- Momo steering wheel
- SAAS X hand brake
- Apexi RSM
- Oil Temp, Water Temp and Volt meter electronic gauge
- Paseo EL44 seats
- Center Armrest
- Tinted windows
- Power windows
- Glanza Clock
Wheels:
- 16" REX 612
Sounds:
- Eclipse CD2000 Head unit
- Clarion 4 channel APX4240 amplifier
- Pioneer 2 way 4" front speakers
- Pioneer 3 way 6" rear speakers
- QMax QINV65 6.5" subwoofer
Lights:
- Crystal Clear Headlight
- Fog Lights
- Philips Blue Vision
Future plans
1) Bigger throttle body
2) Gearbox with LSD
86.3whp/roughly 120-130bhp
i love this starlet. seen it over on ausc and is totallyminted. what i wantmine to looklike almost one day. did the cams and fte rods make a difference? did you have headwork when you fitted the cams also?
considering how far to go with my n/a or just get boost.
anyways lovely motor mate
sam
hey, good to see you over here.
is that power at the wheels?
if so thats the most amount of power ive seen from a 4efe as that would be well over 100 at the fly
Yep. that's power at the wheels. It's breakfast for turbos :lol:
sam
I did mild ported and shaved work on the head. 4efte rods are there because my rpm limiter has been raised to 7200rpm. The cams did make the difference with tuning to aftermarket standalone ECU (at the expense of stalling all the time with a/c turn on)
The UK weather might not be friendly to my specs :lol: In Aussie winter (7 degrees coldest), I am having problem starting it and stalling with a/c
v nice mate did the 4efte inlet manifold and tb make much difference im thinking off putting one on
I'm using 4efte intake manifold only with my stock 4efe tb. I have been trying to search 4efte AUTO tb to fit into my car.
As for 4efte intake manifold, there are noticable gains, but that's because I have move my limiter to 7200rpm.
would the specs of your cams work as well on a 4efte?
also what does that power equate to at the fly?
IMO, the specs should be OK. but the builder of the cam had to reduce the lift slightly for the needed duration after asking if my car is turbo/NA
I don't have the exact calculation of power at the fly. Aussie dyno only measure wheel hp. But from the rough calculation:
2/3 --> 86.4
1 --> (86.4/0.6666)
roughly = 130bhp (could be less; not sure the exact calculation)
  • 4 weeks later...
in my opinion, the specs should be OK. but the builder of the cam had to reduce the lift slightly for the needed duration after asking if my car is turbo/NA
2/3 --> 86.4
1 --> (86.4/0.6666)
wow...stock like mine cant catch you then..marvelous job bro
  • 1 month later...
Recently added a solenoid to the car that turns on when the a/c is turn on.
What the solenoid does is sucking air from "before TB" and pushing it into "after TB"
This helps a bit from stalling when a/c is on.
Currently the car revs at 1260 RPM without a/c, lights, heater. When a/c and lights are turn on, it drops to about 850-900 RPM which is just the point before it stalls.
  • 2 months later...
Hello nic have you got tha inlet manifold on yet matey i sold you?
and i bet that side exit exhaust sound,s nice :D
Nah mate, haven't installed it yet :p
Needs a retune when I do that, and I have other priorities at the moment :p
