adee-ep Posted July 20, 2009 Posted July 20, 2009 can someone explain to me how these work and what are the advantages and diss-advantages. what you need to run them? cheers aidan Quote
ste91 Posted July 20, 2009 Posted July 20, 2009 You don't "need" anything to run one.It's just an alternative to a normal decat/downpipe. It vents the wastegate gases to the atmosphere rather than back into the exhaust system, which can improve airflow and makes a nice sound. However some people say screamer pipes on externally gated turbos sound shitty. Quote
adee-ep Posted July 20, 2009 Author Posted July 20, 2009 ok cheers man i understand what you mean but im a little confused about all the external and internal wastegates, ive only just come over to the glanza scene and was all about n/a before some i dont have an expierence. whats the difference between the two and how do the work? cheers aidan Quote
ste91 Posted July 20, 2009 Posted July 20, 2009 I'm crap at explaining things but I'll have a go.An internal wastegate is built into the turbo, whereas an external wastegate is seperate.Here you can see an exhaust manifold designed for an internally gated turbo:http://www.ukstarletclub.com/forums/upload...-1238818504.jpgnow compare it to the externally gated version which has an extra pipe, this is where the external wastegate goes:http://www.ukstarletclub.com/forums/upload...-1238819263.jpgThe gases are then either plumbed back into the exhaust system or just vented straight out to the atmosphere, hence "screamer pipe".For an internal wastegate you'd use a "seperated" decat which has two pipes, one for the exhaust gases from the turbine (which goes through the exhaust system) and one for the exhaust gas from the wastegate, which goes straight out rather than through the exhaust system. Alternatively (and much more common) you'd just use a normal decat where both the gases from the wastegate and turbine go into the same pipe.An internal wastegate is quite simple, it is operated by an actuator, when it reaches a set pressure the wastegate opens.External wastegates are generally regarded as being "better" although internal ones are quite capable of doing the job, however there can be problems such as boost creep.You're better off googling these things or having a search on the forum though as I said I'm not too good at explaining things. Quote
adee-ep Posted July 20, 2009 Author Posted July 20, 2009 cheers man makes a bit more sense now. il go have a scan around. Quote
Steve GT Posted July 21, 2009 Posted July 21, 2009 all i can say about them is theres one not too far from methe starlets running about 250bhp i think and has been very tunedbut that has a screamer pipe on it and it sounds the dogsi cant describe the sound but it sounds like a psycopath screaming while hurtling towards someone with an axe its immense lol definiatly worth getting in my opinion Quote
adee-ep Posted July 21, 2009 Author Posted July 21, 2009 all i can say about them is theres one not too far from methe starlets running about 250bhp i think and has been very tunedbut that has a screamer pipe on it and it sounds the dogsi cant describe the sound but it sounds like a psycopath screaming while hurtling towards someone with an axe its immense lol definiatly worth getting in my opinionhaha yeh my mates got one on his hybrid ct9 and it sounds amazing Quote
bucketep91 Posted July 21, 2009 Posted July 21, 2009 I've been reading through a lot of your posts bud sounds like you are planning on building a right animal lol you are doing the right thing doing all the research before jumping in head first but mate all of this stuff has been covered before. The search button is your friend Quote
adee-ep Posted July 21, 2009 Author Posted July 21, 2009 I've been reading through a lot of your posts bud sounds like you are planning on building a right animal lol you are doing the right thing doing all the research before jumping in head first but mate all of this stuff has been covered before. The search button is your friendthats the plan ha. yeh want to learn everything before i jump into stuff that i dont no about. did a wee search on most things but couldnt quite find the exact anwser i was looking for mate. cheers for your help aswell mate Quote
bucketep91 Posted July 21, 2009 Posted July 21, 2009 thats the plan ha. yeh want to learn everything before i jump into stuff that i dont no about. did a wee search on most things but couldnt quite find the exact anwser i was looking for mate. cheers for your help aswell matei wasnt saying that to be cheeky bud i was only saying it to save yourself some time if its all in there somewhere, saves waiting around for people posting back.at least your learning first bud thats the best way to do itremember start up a build thread! Quote
adee-ep Posted July 21, 2009 Author Posted July 21, 2009 i wasnt saying that to be cheeky bud i was only saying it to save yourself some time if its all in there somewhere, saves waiting around for people posting back.at least your learning first bud thats the best way to do itremember start up a build thread!i no you werent man just trying to help. yeh i will defo do a build up thread. its in for a full respray a week on friday to so should be looking nice and shiny too. Quote
adee-ep Posted July 21, 2009 Author Posted July 21, 2009 it will be staying the standard black. its like a black with almost a silver flake when the suns on it. where would i get the paint code for it? its a 1996 glanza v ? cheers aidan Quote
