binnzie Posted August 8, 2009 Share Posted August 8, 2009 just wondering is it possible, to put a glanza v bonnet with scoop on a normal sr without having to change the lights and front bumper? Quote Link to post Share on other sites
rob_bower Posted August 8, 2009 Share Posted August 8, 2009 i seem to think ive seen it done somewhere!! you would need to modify the bonnet to line up with the lights though as there is quite a big difference!! Quote Link to post Share on other sites
Steve GT Posted August 8, 2009 Share Posted August 8, 2009 hasnt chanelle done that? try asking her mate Quote Link to post Share on other sites
Bildo Posted August 8, 2009 Share Posted August 8, 2009 I'm assuming that since the lights are a completely different shape the answer would be no, and if it did it would be an incredibly shonky fit.Chanelle did the whole front end, glanza bonnet, lights and front bumper, Quote Link to post Share on other sites
binnzie Posted August 8, 2009 Author Share Posted August 8, 2009 yeh she did the whole front end. ok cheers guys, looks like im gonna do the whole front end then Quote Link to post Share on other sites
chanelle1234 Posted August 8, 2009 Share Posted August 8, 2009 It is possible as lee done it on his sportif.clickIm not sure how safe it is in my opinion though. I would definatly consider getting the whole front end if i was you. chanelle x Quote Link to post Share on other sites
Steve GT Posted August 8, 2009 Share Posted August 8, 2009 there you gotalk of the devil and she shall appear Quote Link to post Share on other sites
binnzie Posted August 9, 2009 Author Share Posted August 9, 2009 yeh just gonna go whole rep build. but need the money first lol Quote Link to post Share on other sites
nazquflilma Posted November 15, 2009 Share Posted November 15, 2009 Is it possible to fit just the scoop on a standard ep bonnet? Quote Link to post Share on other sites
ToyotaTech15 Posted November 15, 2009 Share Posted November 15, 2009 Is it possible to fit just the scoop on a standard ep bonnet?It wouldnt be worth your while,Would take a lot of work to cut the bonnet and seal everything, just aswell changing to Glanza items and saving yourself alot of workGary Quote Link to post Share on other sites
nazquflilma Posted November 17, 2009 Share Posted November 17, 2009 It wouldnt be worth your while,Would take a lot of work to cut the bonnet and seal everything, just aswell changing to Glanza items and saving yourself alot of workGaryYeah but I'm going to do a remix bumper and I really like the scoop lol....hopefully my ep will be one of a kind Quote Link to post Share on other sites
Kennedy Posted November 17, 2009 Share Posted November 17, 2009 It's been done, someone with a red SR I think. Doesn't look good at all as nothing fits properly. Quote Link to post Share on other sites
Ryan5793 Posted November 17, 2009 Share Posted November 17, 2009 i had a glanza bonnet on my SR before i got the front bumper and headlights fitted and there is a huge gap in between..not something i would advise personally..hope this helps Quote Link to post Share on other sites
Galliano Posted November 17, 2009 Share Posted November 17, 2009 Not only does it not look good, but it is ill fitting and it doesn't share the lines of the bonnet.Having said this, Get the headlights too and just cut your front bumper to suit the lights:Doesn't look too bad if i'm honest! Having the lights makes the car look alot better fitting with the bonnet, they don't make it look like it was just stuck there for no reason then. I think the lights suit the N/A bumper too Quote Link to post Share on other sites
nazquflilma Posted November 17, 2009 Share Posted November 17, 2009 i had a glanza bonnet on my SR before i got the front bumper and headlights fitted and there is a huge gap in between..not something i would advise personally..hope this helpsWhat I had in mind was only the glanza scoop on a standard bonnet....not a glanza bonnet on an n/a, just the scoop Quote Link to post Share on other sites
Galliano Posted November 17, 2009 Share Posted November 17, 2009 Glanza scoop on the bonnet would mean cutting the center section out, and having it welded into the current N/A bonnet - which is time, money and hassle in itself.An idea might be to use glanza headlights and bonnet. Buy a cheap glanza front bumper (whichever spec you prefer) and cut the top half off of it, and then do the kind of cut and shut with the bumper. Remix bottom half (or.. from the bit at the top downwards) and then the Glanza top so it fits well with the bonnet.Just worth a thought. Alot less time and money spent doing that than the bonnet. Its fiberglass, filler and some patience to make it look top work! Quote Link to post Share on other sites
Ryan5793 Posted November 17, 2009 Share Posted November 17, 2009 was only trying to help, if you could get that done it would be okay.. Quote Link to post Share on other sites
nazquflilma Posted November 17, 2009 Share Posted November 17, 2009 was only trying to help, if you could get that done it would be okay..Any input is always appreciated Quote Link to post Share on other sites
nazquflilma Posted November 17, 2009 Share Posted November 17, 2009 Glanza scoop on the bonnet would mean cutting the center section out, and having it welded into the current N/A bonnet - which is time, money and hassle in itself.An idea might be to use glanza headlights and bonnet. Buy a cheap glanza front bumper (whichever spec you prefer) and cut the top half off of it, and then do the kind of cut and shut with the bumper. Remix bottom half (or.. from the bit at the top downwards) and then the Glanza top so it fits well with the bonnet.Just worth a thought. Alot less time and money spent doing that than the bonnet. Its fiberglass, filler and some patience to make it look top work!Need to put a couple hours of thought in what to do with the front....so many possibilities. I think I'd better start with the back (more straight-forward job - glanza spoiler + glanza bumper) to give me time to decide.I really need to start a project thread with pics Quote Link to post Share on other sites
