Hey guys, just a little question, will a 4EFTE clutch fit in an N/A?
Reason being is i'd like to replace it soon, and with something better than required.
And without actually having pulled apart an engine/box from a starlet, I have nothing to compare to, any help would be great.
Cheers
Damien
Yup you can ^ (starlet tim did so if i remember correctly in his conversion) but the clutch plate + housing itself goes onto the flywheel all you change on the gearbox is the bearing....would think the clutch to be bigger on FTE so no fit.
  • 2 weeks later...
Gearbox from a 4E-FE fits on the 4E-FTE. Clutch (according to the guy that did my engine swap) said that I needed an FTE fywheel, or my TRD FTE clutch wouldn't fit.
