Issitt Posted September 15, 2009 Posted September 15, 2009 will a starlet uprated manifold fit a tdo4 and my blitz decat?? Quote
scot-ish Posted September 15, 2009 Posted September 15, 2009 nope, will need a flange to fit the td04, so need a tdo4 specific manifold, or im sure now there will be adapter plates Quote
RobSR Posted September 15, 2009 Posted September 15, 2009 Specific mani and downpipe I'm afraid mate!Aswell as oil, water lines IC etc... Quote
Issitt Posted September 15, 2009 Author Posted September 15, 2009 ok cool do you know how much the mani and downpipe will cost? Quote
string Posted September 15, 2009 Posted September 15, 2009 dave does them for bout 1500 i tink. not sure on price but mikey g has the set up n its unreal apparently heard you blew yours up at trax?hope its all good now though Quote
Russleh Posted September 15, 2009 Posted September 15, 2009 1500 for mani and downpipe ???? is that not the price for a whole td04 kit ? Quote
RobSR Posted September 16, 2009 Posted September 16, 2009 ok cool do you know how much the mani and downpipe will cost?it varies I would allow for about 600 quid.. Then you'll need 'gate, oil + water lines etc so it'll soon add up ! Quote
string Posted September 17, 2009 Posted September 17, 2009 i meant full kit sorry. like rob said it soon adds up. is your engine forged? or you running it on low boost? Quote
lanxter Posted September 17, 2009 Posted September 17, 2009 wicked EP does them for alot cheaper matey, remember your not just going to need mani and downpipe though your going to need fueling to match and if your gunna do it right a piggy back or stand alone ecu Quote
RobSR Posted September 17, 2009 Posted September 17, 2009 ^ if you want to run decent boost/power yes you will need fuelling bits. But If you can't afford it all in one hit, you can run up to .7 bar on the td04l on standard ecu/fuelling Quote
liam2368 Posted September 17, 2009 Posted September 17, 2009 can you not run just under fuel cut say .8? i presume that should still give about the same power if not more than a 1 bar ct9. Quote
lanxter Posted September 17, 2009 Posted September 17, 2009 personally id still get the fueling checked and a td04 at 0.7, 0.8 in my opinion isnt as good as a CT9 Quote
Issitt Posted September 17, 2009 Author Posted September 17, 2009 dave does them for bout 1500 i tink. not sure on price but mikey g has the set up n its unreal apparently heard you blew yours up at trax?hope its all good now thoughhow do you know i blew it up at trax?? lol yh just lost boost for a sec and then picked up again but then i looked out the bk and it was just smoke so had to retire i aws doing so well aswell Quote
