anup67 Posted September 30, 2009 Posted September 30, 2009 Will these Clear Indicatior lens' fit an N/A starlet?http://cgi.ebay.co.uk/Starlet-Turbo-EP91-C...id=p3286.c0.m14It shows a glanza but im sure it will fit an N/A wouldn't it?Also how do you change the coloured ones to the cleared ones. is it undoing a couple of scews or does it pop out?ThanksAnup Quote
ste91 Posted September 30, 2009 Posted September 30, 2009 Yes they'll fit.It's simply one screw on the indicator unit, take it out, pop the lenses off, put these lenses on.But you may need to change the bulbs, as far as I know the standard EP91 N/A bulbs are clear, so you will need some orange bulbs or better yet "silvatec" bulbs which look silver/shiny but flash orange. Quote
anup67 Posted September 30, 2009 Author Posted September 30, 2009 Yes they'll fit.It's simply one screw on the indicator unit, take it out, pop the lenses off, put these lenses on.But you may need to change the bulbs, as far as I know the standard EP91 N/A bulbs are clear, so you will need some orange bulbs or better yet "silvatec" bulbs which look silver/shiny but flash orange.thanks for that, i think ill get the chrome bulbs like you said.do you know how to take out the side indicator repeaters? there doesn't seem to have any screws on it. Quote
jambo_ep91 Posted September 30, 2009 Posted September 30, 2009 the side repeaters are on clips either side of the, you will have to pull away your wheel arch liner and push the clips in on the side, they should just push out Quote
Nanglebadger Posted September 30, 2009 Posted September 30, 2009 or you could just carefully pry them out with a screwdriver (CAREFULLY, put a cloth on the paintwork).i think mine even just come out with a good firm grip on them tbh.Phil. Quote
Sparky Posted September 30, 2009 Posted September 30, 2009 Open the bonnet there is a screw on each one. Take that out and its a case of just getting a bit of leverage to force it out of the clip(s). Quote
EP91Bon Posted September 30, 2009 Posted September 30, 2009 I've just bought some of these, should be coming tomorrow - ill let you know how it goes mate Quote
ShafzC Posted September 30, 2009 Posted September 30, 2009 I bought mine off that same seller, fits perfect mate, no worries.Shafz. Quote
ryan lang Posted October 1, 2009 Posted October 1, 2009 i have also bought these and they went straight on took about 5 minutes Quote
