Kaaaty Posted October 2, 2009 Posted October 2, 2009 Filled the starlet lastnight with ultimate was really surprised at how much more responsove the car is and sounds different too. im sure. also took out that double din japanese radio/cd player so i have tunes now. jus need a pocket to put in the gap above stereo Quote
Kaaaty Posted October 2, 2009 Author Posted October 2, 2009 another thing. did starlets come with a japanese radio standard? seems a bit odd. only picked up radio 2 lol Quote
LukeSR Posted October 2, 2009 Posted October 2, 2009 Mine came with the original i think, the black one that glows green? Quote
LukeSR Posted October 2, 2009 Posted October 2, 2009 Eww no lol, thats not standard!The standard is the one that is only single din, i will take a photo later Quote
ste91 Posted October 2, 2009 Posted October 2, 2009 That stuff about the petrol is all in your head. Quote
Kaaaty Posted October 2, 2009 Author Posted October 2, 2009 lol well the power of suggestion is makin my car feel more responsive happy days cheap gains lol Quote
jjayokocha Posted October 2, 2009 Posted October 2, 2009 Yep i always use it, great stuff and a noticable enough difference compared to normal unleaded. Quote
Kaaaty Posted October 2, 2009 Author Posted October 2, 2009 to be fair i think you would feel more difference due to yours being a turbo and if its an import they are tuned to higher ron right? Quote
riko666 Posted October 2, 2009 Posted October 2, 2009 There'll be some compensation in the ECU but otherwise as Ste says, its a placebo - the increased octane rating means the petrol itself is more resistant to detonation, which as a result means you can run more advance timing to create wider/more expansive flame front on combustion, hence a fuller, more complete combustion. And the ECU won't map itself to achieve that, what it will do is release some timing if it was pulling back if there were some minimal knock detected.Higher octane petrol doesn't add power, it allows for it Quote
micky boy Posted October 2, 2009 Posted October 2, 2009 I yoused bp when i first got my apexi ecu on my glanza but my engine mangement lightwas coming on not staying on just a flicker now and then so i rang the guy how mapped my car and he said try vpower it could be the injecsion timeing so i give it a go and it stoped so i think vpower is a bit better than bp well it must be the ecu worked out it had more octaine mind spelling didnt go to school much Quote
Kaaaty Posted October 2, 2009 Author Posted October 2, 2009 There'll be some compensation in the ECU but otherwise as Ste says, its a placebo - the increased octane rating means the petrol itself is more resistant to detonation, which as a result means you can run more advance timing to create wider/more expansive flame front on combustion, hence a fuller, more complete combustion. And the ECU won't map itself to achieve that, what it will do is release some timing if it was pulling back if there were some minimal knock detected.Higher octane petrol doesn't add power, it allows for itahhh cheers for the heads up Quote
Guest Enzo Posted October 2, 2009 Posted October 2, 2009 There'll be some compensation in the ECU but otherwise as Ste says, its a placebo - the increased octane rating means the petrol itself is more resistant to detonation, which as a result means you can run more advance timing to create wider/more expansive flame front on combustion, hence a fuller, more complete combustion. And the ECU won't map itself to achieve that, what it will do is release some timing if it was pulling back if there were some minimal knock detected.Higher octane petrol doesn't add power, it allows for itthis post is a winner. you have a way with words riko Quote
riko666 Posted October 2, 2009 Posted October 2, 2009 Shame you ran away at JAE before I could use them on you to lure you into the tent I pitched Quote
micky boy Posted October 2, 2009 Posted October 2, 2009 There'll be some compensation in the ECU but otherwise as Ste says, its a placebo - the increased octane rating means the petrol itself is more resistant to detonation, which as a result means you can run more advance timing to create wider/more expansive flame front on combustion, hence a fuller, more complete combustion. And the ECU won't map itself to achieve that, what it will do is release some timing if it was pulling back if there were some minimal knock detected.Higher octane petrol doesn't add power, it allows for iti didnt read this bit lol sound like this lad knows his shit lol Quote
Kaaaty Posted October 3, 2009 Author Posted October 3, 2009 haha funnily enough, i was flicking through the channels and fifth gear was on dave ja vu. they said that bp ultimate and shell v power does help make the car perform better. the cars produced the same break, but its response and performance was increased when they used bp and shell compared with the usual stuff. Quote
Steve GT Posted October 3, 2009 Posted October 3, 2009 well whatever anyone says i started putting super unleaded in mine a few months ago and i actually noticed a difference the car seemed more responsive so one way or another you can notice a different in the turbos especially lol Quote
Steve GT Posted October 3, 2009 Posted October 3, 2009 haha sarcastic loli aint saying youre wrong cause you actually are right it doesnt make it faster at all but it does seem to make the car more responsive in my opinion that is lol Quote
Kaaaty Posted October 3, 2009 Author Posted October 3, 2009 lol i have an N/A and i noticed a difference. didnt go faster than normal just felt like it had abit more go in it lol Quote
anup67 Posted October 3, 2009 Posted October 3, 2009 maybe it makes a diffrence after a few tank fulls....but i dont have that kind of money .....i preffer shell standard petrol....very good stufff and cheap aswell Quote
Starlet__SR Posted October 3, 2009 Posted October 3, 2009 Mine reacts better to tesco's 99 octane, bp ultimate it seems less responsive and alot less smoother.Damien Quote
Steve GT Posted October 3, 2009 Posted October 3, 2009 maybe it makes a diffrence after a few tank fulls....but i dont have that kind of money .....i preffer shell standard petrol....very good stufff and cheap aswellexactly right dude i didnt notice it straight away but after about 3 tanks it starts to kick in lol Quote
Glanza_cl Posted October 3, 2009 Posted October 3, 2009 haha i think your all dreaming lmao! if there is any increse of any kind it will be possible 2/3bhp... take into account transmition loss and rolling road resistance and how is that ever going to be noticable?as riko stated... it gives you the opurtunity to run more power safely. plus those with turbo's thinking it makes a difference, in japan they run 100ron fuel we only have 99 so if anything we have a loss get it on a rolling road running ultimate then tweak the timming slightly advanced keeping an eye on det, and with that you might then notice a difference Quote
