nazquflilma Posted October 6, 2009 Posted October 6, 2009 Hi againAs you might have read in my previous threads, my ep91 is 5 door. Just to present the whole picture, I am currently undecided whether to do a 5 door glanza rep or a remix bumper (with clear headlights and remix grill...off course with glanza rear bumper). So at the moment I'm trying to see how much each build would cost me. I've been looking around locally for some side-skirts, however i have my doubts whether the glanza ones will fit, the glanza being 3 door and my car 5. So I have a couple of questions.....will glanza side skirts fit a 5 door ep91? Since I'm expecting the answer to be no, what do you suggest? Are a lot of modifications needed for glanza side-skirts to fit? Will side-skirts off some other car fit perfectly? Would the above mentioned builds look funny without sideskirts? Quote
japcarmaniac Posted October 7, 2009 Posted October 7, 2009 pm me a pic of the your starlet from the side. Quote
ste91 Posted October 7, 2009 Posted October 7, 2009 You can fit Glanza skirts with a little bit of modification. Quote
Galliano Posted October 7, 2009 Posted October 7, 2009 Its do-able, I believe you need to cut some of the back "flick" off of it, so it doesnt cover the door. If you want it to be looking like normal, you could always stick the removed bit, on the door. Quote
Galliano Posted October 7, 2009 Posted October 7, 2009 I knew I saw them somewhere.I hope that helps Quote
nazquflilma Posted October 7, 2009 Author Posted October 7, 2009 I knew I saw them somewhere.I hope that helpsThanks mate...that's one problem sorted Quote
addz Posted October 7, 2009 Posted October 7, 2009 I had an image in my head skirts wouldn't work on a 5 door, pictures proved me wrong.I like it! Quote
Veldugo Posted October 8, 2009 Posted October 8, 2009 Oooooohhh Yeeaaahhh!!! that is my local team!!, Glanziao (www.glanziao.com, you can see the badge on the black car on the right side of the first picture) that is made on fiberglass, they took the original glanza skirt and make a molde, then just make the straight part longer than the original, and the small part on the door is made on a separate molde (that need an art touch to create the molde for it)Here we have a lot of 5 doors Glanzas, every body is making that conversion, is a kind of...fever or something. Quote
nazquflilma Posted October 8, 2009 Author Posted October 8, 2009 Oooooohhh Yeeaaahhh!!! that is my local team!!, Glanziao (www.glanziao.com, you can see the badge on the black car on the right side of the first picture) that is made on fiberglass, they took the original glanza skirt and make a molde, then just make the straight part longer than the original, and the small part on the door is made on a separate molde (that need an art touch to create the molde for it)Here we have a lot of 5 doors Glanzas, every body is making that conversion, is a kind of...fever or something.So it's not just as simple as getting original skirts and cutting them so the door opens? Quote
japcarmaniac Posted October 9, 2009 Posted October 9, 2009 it should be because the cars the same length just smaller front door to fit the back one in. Quote
nazquflilma Posted October 9, 2009 Author Posted October 9, 2009 So it's not just as simple as getting original skirts and cutting them so the door opens?Thanks bud, hopefully I'll have started my project by xmas look out for the thread Quote
