chr15_7_t_ Posted October 15, 2009 Posted October 15, 2009 i was just gna use the ct12 turbo from my mate but seems to be pointless.. so im saving for td04 conversion .im not wanting to go over 200bhp id be happy with about 180 to 190bhp..i know il get told to forge but to expensive for me lol,i know il get told to use a hybrid but i dont want to and il get told to buy aftermarket ecu but i dont have that money right now..but if i do everything then later on when i have money i can simply buy an ecu and get her mapped to about 200bhp:)wat i have so far...4efte block1.4mm metal head gasket5efhe headboost gaugeturbo timerjust about got a fmic to :harhar:what i know i need to buy...td04 manitd04 decattd04 turbowater and oil pipes for the td04boost controlerthe bit that i dont realy no is fueling..i no i need to up the fuel but what all do i need without management if im wanting to run 180bhp atleastim guesing ill need..fpr...recomend makes?injectors.....recomend?uprated fuel pump....recomend?if ive missed anything please help Quote
ste91 Posted October 15, 2009 Posted October 15, 2009 You can get 180 on a CT9.Sparky made 185bhp/185ftlb with:air filter exhaust systemexhaust manifolddecatFMICtuned on E-manage blue Quote
chr15_7_t_ Posted October 15, 2009 Author Posted October 15, 2009 is e-manage blue expensive?im not wanting to be runing the turbo in the limits though..and if i do a td04 i can get it ner 200bhp once i have the money for aftermarket ecu :harhar: Quote
chr15_7_t_ Posted October 15, 2009 Author Posted October 15, 2009 i seen one of them blitz on here but you are ther expensive same with hybrids..td04 are generaly quicte cheap tubbys you can get a good one on ebay for £150 :harhar:.looked at the garrets aswel but it was a t25 but decided to go for the td04 Quote
ste91 Posted October 15, 2009 Posted October 15, 2009 The same setup on a hybrid CT9 would be fine. A Blitz K1 would be good but they're fairly expensive/uncommon. A Tong Turbo's GT spec would be fine.Alternatively if you fancy spending some money I've been looking at these Garrett turbos:http://www.turbobygarrett.com/turbobygarrett/products/turbochargers.htmlTake a look at the GT20 series, I think one of those would probably be better than a hybrid, but more expensive and a fair bit of fucking around as you'd have to get a manifold and downpipe made up to suit them and rotate the housing to fit properly. Quote
ToyotaTech15 Posted October 15, 2009 Posted October 15, 2009 If it was me I'd go for a gt-spec hybrid or similar hubris ct-9 if that's the power you would like to run.Gary Quote
ToyotaTech15 Posted October 15, 2009 Posted October 15, 2009 If it was me I'd go for a gt-spec hybrid or similar hybrid ct-9 if that's the power you would like to run.Gary Quote
chr15_7_t_ Posted October 15, 2009 Author Posted October 15, 2009 arnt that turbos expensive though? Quote
ToyotaTech15 Posted October 15, 2009 Posted October 15, 2009 Turbo itself through the I commerce on the site is £465 check Enzo's tong turbo shop,Minimum requirements of a uprated actuator blow off valve relocated filter and uprated rocker cover breatherAlthough I would add a decat and manifold and management if running above fuel cutGary Quote
chr15_7_t_ Posted October 15, 2009 Author Posted October 15, 2009 no wanting to pay that just for a turbo though :/ thats why im going td04 :harhar:.can anyone help with the fueling Quote
Steve GT Posted October 15, 2009 Posted October 15, 2009 fcd and rising rate fuel pressure regulator will sort the fuelling. get a hks or jam FCD and get a RRFPR off somewhere like tm-developments. should cost no more than 200 quid id say probably a lot lessbut i will say td04's take a lot longer to come on boost than the hybrids which kick in pretty much straight away so a td04 wont be as quick in acceleration lol Quote
chr15_7_t_ Posted October 15, 2009 Author Posted October 15, 2009 i know they dont spool as quick :/wats an rrfpr? Quote
ToyotaTech15 Posted October 16, 2009 Posted October 16, 2009 It's a rising rate fuel pressure regulatorGary Quote
Russleh Posted October 16, 2009 Posted October 16, 2009 well your gonna have to buy the td04 mani downpipe etc so wont you be spending about the same as if you were just to hybrid it. will bolt straight on and you can upgrade everythin else at a later date. Quote
chr15_7_t_ Posted October 16, 2009 Author Posted October 16, 2009 how much a hybrid cost roughly? Quote
Steve GT Posted October 16, 2009 Posted October 16, 2009 erm gt spec hybrids are new at £460 rouhghlt and the td12 hybrids which apparently pack a better punch are around £650 but the td12's are fairly new and are still being tested but the feedback so far looks quite good Quote
Steve GT Posted October 16, 2009 Posted October 16, 2009 Link here dude if you want a lookGT-Spec Hybrid Quote
chr15_7_t_ Posted October 16, 2009 Author Posted October 16, 2009 cheers :harhar:..will go for a peak the now..although i stil fancy the td04 lol Quote
Steve GT Posted October 16, 2009 Posted October 16, 2009 yeh the thing that was stopping me getting one is the big delay in spool up time. acceleration is the key and the hybrids seem to be the best Quote
chr15_7_t_ Posted October 16, 2009 Author Posted October 16, 2009 the only thing that gets me with them is the price :/...im wanting to use my car at crail raceway on the drag strip so im wantn sutin quick of the mark im shure the td04 would be oryt if your siting ther at 4,000 rpm before take off hahaha Quote
Steve GT Posted October 16, 2009 Posted October 16, 2009 yeh but once you change gear it wont spool up again till like 3500-4000 rpm lol whereas a hybrid will kick in sttraight away lol Quote
chr15_7_t_ Posted October 16, 2009 Author Posted October 16, 2009 do you ever see many second hand hybrids floating about? Quote
Ryan-11 Posted October 16, 2009 Posted October 16, 2009 a td04 aint that laggy, trust me if you go td04 you will love it :harhar: ive had a hybrid ct9 before and wasnt to impressed with it Quote
Ryan-11 Posted October 16, 2009 Posted October 16, 2009 oh and standard fuel injectors will b fine for running 1 bar on a td04, i ran my td04 on standard fueling at .8 bar the ecu was fueling it fine, it made 184.9 bhp on the rolling road :harhar: Quote
Steve GT Posted October 17, 2009 Posted October 17, 2009 do you ever see many second hand hybrids floating about?no lol you get maybe one for sale every few months lol they are quite rare parts for sale lol Quote
