Steve GT Posted November 18, 2009 Posted November 18, 2009 hellowell got my guages wired up to light up, my boost gauge is also piped in but need some pointers in the oil pressure gauge and oil temperature gauge informationpics are below of what the ends look like could someone please tell me how to connect them and where abouts they should go please. help would be appreciatedRight first is the oil pressure gauge, a wire comes out the gauge then connects to a metal attachment. the wire goes in the top then theres a threaded whole on one end then a single flat slide on connecter at the other. Pics belowSorry for the poor quality pics its a good camera aswell dont know why its being gayanyway put a few pics up for different angles if it helpsso where does the threaded end screw into and what connecter in the engine bay connects to the slot on the metal pressure sensor?Now for the oil temperature oneThis ones easier to explain. its basically a lond circular bit of metal whick looks a bit like the lambda sensors so im guessing it works on the same principle but need to know where it goes. theres also a seperate bit on it which basically once the bit of metals in it screws over it to secure it. Pics belowCan anyone help out then please im no good at gauges and fitting as you can see haha cheers Quote
Marck glanza V Posted November 18, 2009 Posted November 18, 2009 for oil temp it connects into the side of where the oil filter is there should be a bolt plugging the holefor oil pressure you need one of these this is the correct size even though it says subaruhttp://cgi.ebay.co.uk/Subaru-remote-oil-ga...=item3ca6bdce02this connects where your oem pressure switch goes at the bottom right hand side of the block and allows you to fit the new sensor and the old this way of attatching the gauges is easiest as with sandwich plates there is no roommarck Quote
Steve GT Posted November 18, 2009 Author Posted November 18, 2009 oh and just looked on that link for aGay and its the same thing i already have lol the t piece is on the pictres above dude Quote
Steve GT Posted November 18, 2009 Author Posted November 18, 2009 you legend thatks so muchand where abouts in the engine bay should the pressure sensor go and wheres the wires plug in again please lol Quote
Newbe Posted November 18, 2009 Posted November 18, 2009 This may help check wallaceglanza's thread shows how he has done ithttp://www.ukstarletclub.com/forums/index....=oil+temp+gaugehope it helpsMatt Quote
Steve GT Posted November 18, 2009 Author Posted November 18, 2009 cheers mate il have a look now Quote
Marck glanza V Posted November 18, 2009 Posted November 18, 2009 when looking at the engine it is the bottom right hand side of the block Quote
Steve GT Posted November 19, 2009 Author Posted November 19, 2009 right nice one dude so this little t-piece should just replace the standard one and should screw straight into it yeh? Quote
chr15_7_t_ Posted November 19, 2009 Posted November 19, 2009 i thought ther was a bit more work than this to wire up oil gauges so i didnt bother buying any :/...but you have just persauded me to go buy some lol roll on friday for pay day so i can order mysel some new gauges Quote
Steve GT Posted November 19, 2009 Author Posted November 19, 2009 well the oil temp looks well easy but dont be sure the oil pressure is any easier lol going to try and get my head round it now lolupdates later on my build thread and a pint for mark if it works and i ever meet him haha Quote
WallaceGlanza Posted November 19, 2009 Posted November 19, 2009 Remove the sensor on the end of the tee as it looks like a standard oil pressure switch, so you want to put the existing one off your car there then put the other end of the tee where the standard oil pressure switch was.Fitting the oil temp in the place shown above isn't necessarily easier than a sandwich plate as you'll still need to either space out the powersteering bracket or drill a hole through it, as above though you can see it in my thread. Quote
Steve GT Posted November 19, 2009 Author Posted November 19, 2009 brilliant cheers mate was hoping to get hold of you lol cause I've heared you the one who knows best lol Quote
nicwan8 Posted November 19, 2009 Posted November 19, 2009 From my experience dealing with oil gauges, don't tee directly into the block.Use a sandwich plate for the oil filterorUse steel braided lines from the oil pressure switch (and tee it there)The reason for that is, the sensors are made of brass and I have seen so many times the sensor tip snap and fall into the bottom end ($$$ alot to fix it) Quote
Steve GT Posted November 19, 2009 Author Posted November 19, 2009 hmmmm that aint goodso can someone please explain what a sandwich plate is exactly, where to put it and what it does lolno links please cause I've looked at them all and they dont tell me exactly what i want to know just how to fit them lol Quote
Marck glanza V Posted November 19, 2009 Posted November 19, 2009 if you use a sandwich plate you need to grind away part of the powersteering bracket you should just get that part i showed you on the first post as it is much cheaper and thats what nicwan8 is talking about other than the plate Quote
Steve GT Posted November 19, 2009 Author Posted November 19, 2009 I've got that t piece you gave me the link too lol its in the pictures above dude well i had a quick look earlier, found where it needs to go and its basically a downpipe take off jobby so hopefully going to have a play tomorrow at getting it on lol Quote
Marck glanza V Posted November 19, 2009 Posted November 19, 2009 I've got that t piece you gave me the link too lol its in the pictures above dude well i had a quick look earlier, found where it needs to go and its basically a downpipe take off jobby so hopefully going to have a play tomorrow at getting it on lolthe one i gave you the link to has the braided line on it though Quote
Steve GT Posted November 19, 2009 Author Posted November 19, 2009 ahhhh ryt i seewell wallce said i should just be able to put the standard connectors from the car on the t piece and it should workil try it tomorrow and see if it doesnt work il have to order one of them scooby ones you gave me the link to on eGay lol Quote
Marck glanza V Posted November 19, 2009 Posted November 19, 2009 it should still work fine nicwan8 was just telling you a safety precautionbut ive seen a few connected how you will be with no problems Quote
Steve GT Posted November 19, 2009 Author Posted November 19, 2009 nice one just hope it fits lol il try tomorrow if it doesnt im going to go mental haha Quote
Marck glanza V Posted November 19, 2009 Posted November 19, 2009 nice one just hope it fits lol il try tomorrow if it doesnt im going to go mental hahaif the size is 1/8 bsp it will fit Quote
Guest Eamon Posted December 22, 2009 Posted December 22, 2009 Can this be used for the oil temp? if not where can i get it?http://www.demon-tweeks.co.uk/products/Pro...mp;pcode=GLOOTS:EDIT:And then use this gage do you just run a wire between http://www.demon-tweeks.co.uk/products/Pro...SMITOT1-1452-15 Quote
Lee_EP82 Posted December 22, 2009 Posted December 22, 2009 I heard you can use 1 of these sump plug adapters for your oil temp sender which is what i think i will be using if someone can find out the sump plug thread Quote
Steve GT Posted November 19, 2010 Author Posted November 19, 2010 bumping this upis this what i e=need for an oil pressure gauge unstallationClick Quote
Frankieflowers Posted July 14, 2021 Posted July 14, 2021 On 11/18/2009 at 6:36 PM, Marck glanza V said: for oil temp it connects into the side of where the oil filter is there should be a bolt plugging the hole http://i41.photobucket.com/albums/e278/weeJohn/temp.jpg   for oil pressure you need one of these this is the correct size even though it says subaru  http://cgi.ebay.co.uk/Subaru-remote-oil-ga...=item3ca6bdce02  this connects where your oem pressure switch goes at the bottom right hand side of the block and allows you to fit the new sensor and the old   this way of attatching the gauges is easiest as with sandwich plates there is no room  marck Hi! I am in the same situation looking for the Oil temperature location and oil pressure locations to fit the sensors. Unfortunately this thread is old and the pictures and the link are not available anymore. Would someone help me out to do what Marck explained? Quote
