Nads Posted November 24, 2009 Posted November 24, 2009 Hey guys again.Just wondering at what level of Revs does people change gear when normal driving.. and racing... i change around 2.000 to 3.000 revs normal driving.. and Racing around up to 4 to 5.000What do you do ? Quote
chriswoodfto Posted November 24, 2009 Posted November 24, 2009 is your a turbo or N/a? i have a glanza-=red line all the way!!! Quote
Paul Sr Posted November 24, 2009 Posted November 24, 2009 im bad i change at 5 all the time.!Advanced memeber now yea!!! Quote
LukeSR Posted November 24, 2009 Posted November 24, 2009 Normal change around 2.5k - 3k.Racing? lol, erm just over 5k, power stops at 5.5 i think Quote
EN V Posted November 24, 2009 Posted November 24, 2009 about 2-2.5k normalabout 7k when racingglanza v Quote
Nanglebadger Posted November 24, 2009 Posted November 24, 2009 depends how pissed off i am at the noob in my road! lolPhil. Quote
Jae-Glanza Posted November 24, 2009 Posted November 24, 2009 Glanza VNormal driving - 2-3kDepends what I'm 'racing' to be honest, If its a tight one i'll take her right up the revs. If some saxo furio comes side by side at santa, i stick too low boost and launch in reverse. you know what i mean ;p haha Quote
Nads Posted November 24, 2009 Author Posted November 24, 2009 Glanza VNormal driving - 2-3kDepends what I'm 'racing' to be honest, If its a tight one i'll take her right up the revs. If some saxo furio comes side by side at santa, i stick too low boost and launch in reverse. you know what i mean ;p hahahhahaha Quote
Graeme Posted November 24, 2009 Posted November 24, 2009 Normal driving normaly between 2-3k, if im enjoying more 'spirited' driving then its change at 6500rpm. peak power is at 6700 on turbo's with a standard set-up i think. Quote
ShafzC Posted November 25, 2009 Posted November 25, 2009 No rev counter so no Idea, I'm assuming 2-3k normal driving and "spirited driving" is around 5kShafz. Quote
Michel_M Posted November 25, 2009 Posted November 25, 2009 Just 'cruising' around town I guess, not burning away money etc. I'd say for normal driving 2.5-3k and when 'racing' usually about 6-6.5k, since a totally stock 4E-FTE (at least my car) will die out after about 6.3k (went for a dyno run of my car). Quote
ste91 Posted November 25, 2009 Posted November 25, 2009 When ragging it in the N/A I always changed near the redline. Although the peak power is around 5.5k the peak torque was somewhere around 4k which is where the revs land (right at the start of the powerband) when you change near the redline. I found with the N/A that it needed to be driven hard to get anything out of it, you lads with turbos probably don't need to. Quote
Sparky Posted November 27, 2009 Posted November 27, 2009 Hey guys again.Just wondering at what level of Revs does people change gear when normal driving.. and racing... i change around 2.000 to 3.000 revs normal driving.. and Racing around up to 4 to 5.000What do you do ?If your changing between 4 and 5 racing then your gonna get beaten by most things!I usually rev it to about 6.5k-7k my AVCR used to show my shitty turbo running out of puff after about 6.5k Quote
