lukerobz Posted December 27, 2009 Posted December 27, 2009 hey my fuel dusent light up any more i think the bulb has gone would it still work if i changed the bulb but changed the lot with a diffrent colour??????? how would i do it ?????? are the bulbs inside the cluster or behind it??luke Quote
SiCaln Posted December 27, 2009 Posted December 27, 2009 bulbs are inside the cluster, two screws above then pull plastic cover off, two screws at base of cluster one at top, reach behind disconnect speedo drive then pull cluster out Quote
lukerobz Posted December 27, 2009 Author Posted December 27, 2009 thanks mate do you know if it would still light up ass clear if i changed the bulbs to a dif colour wen i am ther?? Quote
nutnut Posted December 27, 2009 Posted December 27, 2009 It will light up whatever colour bulb you put in.I have changed all mine to blue. Quote
Shahzad Posted December 27, 2009 Posted December 27, 2009 Hi,Im having trouble taking the speedo cabe out. How did you do it? Quote
5T4R7ET N/A Posted December 27, 2009 Posted December 27, 2009 removing the speedo cable is not easiest of tasks. i found that it helps remove bug piece of trim that holds the front speaker in. its just a few screws and then you will be able to get a better view of it when your underneath looking up at the back of the cluster.a long screw screw driver helps to slide the speedo cable off once you got a better view.hope that helps Quote
nutnut Posted December 27, 2009 Posted December 27, 2009 Hi,Im having trouble taking the speedo cabe out. How did you do it?I did not remove the speedo cableHad trouble removing itSo i done it by feel Took a fooking long time , but got there in the end. Quote
Dan Evans Posted December 27, 2009 Posted December 27, 2009 mine came out alright, just feel round the cable and pull (sounds abit rude lol) Quote
lukerobz Posted December 27, 2009 Author Posted December 27, 2009 chears boys I did not remove the speedo cableHad trouble removing itSo i done it by feel Took a fooking long time , but got there in the end.wer did u get the bulbs pal are they a sertain type or can i pick em up at my local garage??/ Quote
nutnut Posted December 28, 2009 Posted December 28, 2009 Got mine of e-bayhttp://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=350135589110In halfords it costs a fiver for just 2 bulbs (rip off) Quote
Laura_ep91 Posted December 29, 2009 Posted December 29, 2009 Im planning on changing mine over next few weeks feeling pink but most pro red Quote
jason_l Posted December 29, 2009 Posted December 29, 2009 About time you changed the bulbs dude!I thought you may have done it when you had the speedo out? The bulbs are just on the back of the speedo unit so can easily be changed. should look even more sexual with some nice new bulbs.Jason Quote
