chr15_7_t_ Posted January 11, 2010 Share Posted January 11, 2010 basicly...drive round tightish corners at slow speed(15mhp rufly) and something makes like a knocking..now..drive round tightish corners at the same speed but holding the clutch in and it dosnt knock?in straight lines or round corners that arnt to tight there is no sound at all everything is ok me nd my mate jacked up the car..all bellhouse bolts are fine.driveshafts seem ok.mounts are ok.we had the car runing in 1st gear when it was off the ground and had it at 20mph turning the weels but the noisde wasnt there(guesn ther has to be strain) it was a replacement gearbox just put in..i was told it was reconditiond by smr it was stil all clean with the holograpic stickers. mate think it could be the gearbox but im complety lost...HELP PLEASE!!!! Quote Link to post Share on other sites
chr15_7_t_ Posted January 11, 2010 Author Share Posted January 11, 2010 Quote Link to post Share on other sites
lukEp Posted January 11, 2010 Share Posted January 11, 2010 sounds like drive shaft mate Quote Link to post Share on other sites
chr15_7_t_ Posted January 11, 2010 Author Share Posted January 11, 2010 why dosnt it clunk round corners when i have the clutch in thoug?:S Quote Link to post Share on other sites
lukEp Posted January 11, 2010 Share Posted January 11, 2010 dunno might be because you have took load off the driveshaft? might be gear box but clunking noise usually cv joint worn if its cv joint the clunckin will get worse the more you drive it and will be noiser the tighter the corner/faster you travel Quote Link to post Share on other sites
chr15_7_t_ Posted January 11, 2010 Author Share Posted January 11, 2010 i just dont have a clue ...unles i got muged when i bought the box and the guy new it was dodgy..anyway of checking cv?ther dsnt seem to be play in the safts tough Quote Link to post Share on other sites
chr15_7_t_ Posted January 11, 2010 Author Share Posted January 11, 2010 bump Quote Link to post Share on other sites
chr15_7_t_ Posted January 12, 2010 Author Share Posted January 12, 2010 Quote Link to post Share on other sites
The_Notorious_C_A_T Posted January 12, 2010 Share Posted January 12, 2010 Doesn't need to have play in the shaft bud for the cv joint to be not great.One of mine was knocking, and when I pulled it apart, all looked fine just when moving it about at certain points it sounded rough. And there was plenty of grease in there by the look of it as well.Dinna break it, shame to see the work and money not getting enjoyed by yourself. Quote Link to post Share on other sites
Guest cheshireglanza Posted January 12, 2010 Share Posted January 12, 2010 sounds like drive shaft to me Quote Link to post Share on other sites
chr15_7_t_ Posted January 12, 2010 Author Share Posted January 12, 2010 anyway off teling what driveshaft? Quote Link to post Share on other sites
The_Notorious_C_A_T Posted January 12, 2010 Share Posted January 12, 2010 Which way do you turn when the noise happens? Quote Link to post Share on other sites
chr15_7_t_ Posted January 12, 2010 Author Share Posted January 12, 2010 i think its worse turning right? but it could be slightly bad left to?i noticed the car wants to pull left Quote Link to post Share on other sites
The_Notorious_C_A_T Posted January 12, 2010 Share Posted January 12, 2010 If it's when you turn right it's the left shaft. Quote Link to post Share on other sites
chr15_7_t_ Posted January 12, 2010 Author Share Posted January 12, 2010 no bother cat cheers il need to do some investigating..if anyone else wants to add sum help please do ;).. Quote Link to post Share on other sites
The_Notorious_C_A_T Posted January 12, 2010 Share Posted January 12, 2010 Ironic thing is that my passenger shaft is fucked as well lolMaybe your car is like my car more than you thought Quote Link to post Share on other sites
chr15_7_t_ Posted January 12, 2010 Author Share Posted January 12, 2010 your car is just a weapon compared to mine now lol...you buying new ones or 2nd hand?i got quoted just over £500 inc vat from toyota Quote Link to post Share on other sites
The_Notorious_C_A_T Posted January 12, 2010 Share Posted January 12, 2010 bought a set second hand but replaces the cv's and joints but the banding clips are shit so waiting for new ones and a new tool as well! It's gay like. Quote Link to post Share on other sites
Raz Posted January 12, 2010 Share Posted January 12, 2010 My car does the same noise, its the CV joints. under accelaration while turning you can hear, gets louder with sharper turns or more acceleration, happened after doing drifts in the snow for about 3 hours. Quote Link to post Share on other sites
chr15_7_t_ Posted January 12, 2010 Author Share Posted January 12, 2010 how can i check this?how much new cv's? Quote Link to post Share on other sites
Lawsy Posted January 12, 2010 Share Posted January 12, 2010 how can i check this?how much new cv's?Well i would say the best way is by driving it, if the CV joint is making a heavy knocking noise when loading it up i.e going round a corner then its going to be that joint. Also you will be able to tell when you have taken it out of the hub, because when you wiggle it around it will feel like its grinding and knotchy if that make sense? Or even by jacking the car up and spinning the wheel freely you may be able to hear it, depends how bad its got?Not sure how much new CV joint are for starlets, but shouldnt be to expensive i shouldnt think, its when you have to buy the shafts as well you break the bank. Sorry aint very good at explanations via text lol. Quote Link to post Share on other sites
Asad Posted January 12, 2010 Share Posted January 12, 2010 Put it in reverse when going back it should grind/make a noise.....i think? Quote Link to post Share on other sites
chr15_7_t_ Posted January 12, 2010 Author Share Posted January 12, 2010 i had the car jacked up and it wasnt doing it...only seems to be when its on load? Quote Link to post Share on other sites
The_Notorious_C_A_T Posted January 12, 2010 Share Posted January 12, 2010 If you can get the shaft off, when you give the outer cv a test, you'll hear a clonk/knocking like noise. Just got to remember when the cars weight on it and it's getting power it would be amplified. Quote Link to post Share on other sites
chr15_7_t_ Posted January 13, 2010 Author Share Posted January 13, 2010 il do this tomorow night if i dont get home to late thanks for the help cat..how much were u for your cv's if u dont mind me asking? Quote Link to post Share on other sites
