Hi
I am a new member and I own Glanza S 1.3. I need a lot of help on how I can increase the power of the engine without adding a turbo. Can someone please give me useful info on how I can tune this 1.3 engine??
your help will be much appreciated
Thanks
If you want a serious power increase you'll be looking at cams/headwork/higher compression/raised rev limit.
More money than it's worth usually.
  GlanzaS1.3 said:
Hi
Thanks
Manifold
De-cat
air filter
Piggyback ECU
Boost controller
Free boost DE-stricter
loads more but forgotten
Hey dude,
I have added the cat-back exhaust on my Glanza S it made 93.8bhp with air filter but if you try and get a de-cat made up that should increase the power.
Craig
  Nads said:
Manifold
De-cat
air filter
Piggyback ECU
Boost controller
^^^ it's not a tubby mate lol, boost controller would do very little :D
but yeah as stated will get very exspensive very quickly. but simple air filter, exhaust, decat should free up some power :(
  Nads said:
Manifold
De-cat
air filter
Piggyback ECU
Boost controller
Can I take these parts mentioned from a GLANZA V or they aren't compatible??
  Craig_N said:
Hey dude,
Craig
Is it expensive to install a de-cat?? what is the main difference between the de-cat and a cat-back??
  Glanza_cl said:
air filter will be and piggy back ecu, but mani decat etc etc wont fit mate as there designed for the turbo engine.
so from where can I get a manifold and a decat which fits the Glanza S??
Well a cat-back still has the cat which restricts the flow in the exhaust but if you get a decat which will open a bit more power mainly top end but you might have a problem with mot's then emissions being to high.
A Cat-back system is the exhaust system from the Cat, all the way to and including the back box
A Decat is a pipe welded in place of the cat, removing the restriction caused by the catalytic converter :(
I was quoted about £89 for a Decat on my N/A
Too slow lol
  Amjad786 said:
A Cat-back system is the exhaust system from the Cat, all the way to and uincluding the back box
Too slow lol
To be honest with you guys I am freaking myself up on starting to tune up the Glanza S but I don'e know from where to start this process
best bit of advice ^
get some opinions on whos good with exhausts around your area and pop down to see them, best to get a full system with a 2 flanges in the middle so you can put the cat back in (make sure you get them to show you that it fits straight back in to the stock place)
  Glanza_cl said:
^^^ it's not a tubby mate lol, boost controller would do very little :(
but yeah as stated will get very exspensive very quickly. but simple air filter, exhaust, decat should free up some power :D
woops lol got carried away.. you can use the boost controller for show !
This is how i would do it if i had and wanted to keep the N/A not including any suspention or brake mods
- Cat-Back exhaust system (2")
- Decat Pipe (also 2")
- 4 branch manifold
- Custom cold air intake mouting the airfilter as close to the front of the car as possible without going too near anything warm
- 4efe Corolla intake manifold
- Some sort of piggyback ecu to trim the fueling and make the most of the above modifications
- lightweight flywheel
- Ported/polished head with some GOOD cams 5efhe cams are good put some better spec'ed cams would obviously be better
- Custom high comp pistons
As you can see it soon gets expensive.
Ive allways fancied trying to put a yaris tsport 1.5 in a starlet with its VVTi, 105bhp as standard (toyota claim 108), as these engine can gain anything up to like 20bhp from simple breathing mods
